How much boost for built motor?
Old Jun 28, 2002 | 09:02 PM
69Roadster's Avatar
My short block is rebuilt with JE pistons and Eagle rods. Currently running an ASP (2or3lb?) upper pulley and a PSP 2 lb lower pulley. I'm thinking of upping the boost more. Any suggestions of what to change to or what is safe? How much do you think adding boost would give me at the track or on the dyno say for a 4 or 6 lb lower? Thanks.
Old Jun 28, 2002 | 09:13 PM
Probleminfected's Avatar
well if the rods are as safe as manly then 20+ psi of boost is fine
Old Jun 29, 2002 | 02:50 AM
CHIKIN1's Avatar
Built "L" in North Al????...We Need to MEET UP!!!!
It depends on compression ratio of your new motor!!!
I'm having my new engine built with 8.2:1 compression for close to 30psi!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
424HP/528ft.lbs @ Normal Temp. w/o N2O
LFP 2600 P.I. Stall Converter
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
NEXT:
Built Shortblock w/Ported Heads
Monster Box Tranny
JDM 205 blower and 100mm MAF
AND DEFINITELY SOME BIGGER SLICKS
Old Jun 29, 2002 | 03:44 AM
DaveRed99's Avatar
Lightbulb im shure......
You could put a 6 Pounder with no problem's. That's if your not going to go nitrous and all boost.
Old Jun 29, 2002 | 09:58 AM
69Roadster's Avatar
20+ psi?!? Bet the truck would move along pretty good with that much boost . I will probably upgrade to a 6lb lower then. Don't plan to use nitrous. Thanks for the advice.
CHIKIN1
Ya I would like to meet up sometime. Looks like you got quite a truck there. I am probably going to the Hooters car show this Wednesday in Huntsville. You should bring your L. There is a red one there usually. Could have 3 Lightnings in one parking lot.
Hey there was a black Lightning at the dragway a few weeks ago. Ran a guy I know in a black Supra and spanked him pretty good. Was that you?
Old Jun 29, 2002 | 10:22 AM
CHIKIN1's Avatar
You mean Jimmy in the Supra, if so then that was me...BTW, that was w/o N20!!!!
Red one with 22's on it...if so thats Dave Dionne...I know him too!!!
On Wednesdays I work about 14-18 hours....I am part owner of a car lot and have to go to the auction on Wed. night!!!
We're gonna do some street racin tonight if your interested E-mail me...my address is in my sig!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
JL 3# Lower Pulley
JDM Cold Air
JDM Boost Bypass
JDM Cobra R pump
JDM Eletric Fan
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
NEXT:
Monster Box Tranny
Old Jun 29, 2002 | 11:23 AM
Jwasted's Avatar
Sup gents I am from AL also. I just bought a brand new L, and plan on building her a bit. I can always use advice. Look me up if your ever in tuscaloosa
Old Jun 29, 2002 | 11:24 AM
69Roadster's Avatar
Yep I was talking about Jimmy. I was there with the other Supra guys. That was actually the last weekend I owned that Supra. It was a black BPU 6-speed. Car ran 7.70s @ 93.5mph w/o nitrous, probably would have been a good race for your L. I sold it to someone in Tampa, FL. I think Jimmy is happy to have the only black Supra in town again .
Didn't know you weren't spraying on that run with Jimmy. I asked him what happened and he said you had a 150 shot on the truck. Didn't say you used it, I just assumed you did. Awesome times for not spraying!! I just got my Lightning last weekend and haven't taken it to the track yet. The previous owner has a nitrous free 7.88 best in the 1/8th and 12.30 in the quarter. Not bad but I'm hoping for more...
That red L had huge rims so it is probably the same truck. I only stopped by for a second so I didn't get a chance to meet the guy. 18 hour work day? Wow, now that's a long day. I'll email you if I can make it tonight. Have plans already but that aren't solid yet.
Old Jun 29, 2002 | 06:07 PM
CHIKIN1's Avatar
7.76 @ 89 MPH would be my best ET so far w/o N20 and W/O my new converter...If weather was permitting enough I believe i can get her to go a 7.5x or so w/ the new converter...And hoping for .20's or teens with the JUG!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
JL 3# Lower Pulley
JDM Cold Air
JDM Boost Bypass
JDM Cobra R pump
JDM Eletric Fan
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
NEXT:
Monster Box Tranny
Old Jun 29, 2002 | 06:36 PM
Jwasted's Avatar
Thats a nice truck chikin, maybe i can see it one weekend.
Old Jun 29, 2002 | 06:50 PM
Nathan's Avatar
Heat control?
So if you're planning on running 20+ lbs of boost out of the stock eaton, how are you going to control heat? I'd think that the intake charge would be so hot you'd have to pull way back on your tuning to prevent detonation ...
Has anybody done work to run high boost *efficiently* on our motors?
Old Jun 29, 2002 | 10:36 PM
99svtlightning's Avatar
Big boost and the Eaton work fine. I am running close to 20psi. At the Mod Shootout today I ran a 2lb upper and 10lb lower and ran consistant 12.0's w/ a conservative chip to break in the motor and it was very hot and humid. My friend has the same setup and used his race chip and he was running 11.80's.
Old Jun 30, 2002 | 05:02 AM
NCETRY's Avatar
A built short block like 69Roadster has should handle a good amount of boost within reason. I recently put in a built engine and slapped on the new 8# lower pulley and I think I blew the boost sylinoid cause now at high boost the engine futters and and does not excellerate but it does not dump all the boost. If anyone has had this problem I would like to know how you fixed it. I plan to try some parts off my buddies L.
