Installed JLP Traction Bars!
Old Jun 28, 2002 | 08:39 AM
99svtlightning's Avatar
I had a chance to play around a little in the truck w/ my new JLP traction bars and they hook up great. I'll have my first runs on them at the track this weekend. See you at Cecil.
Old Jun 28, 2002 | 08:46 AM
BfB's Avatar
BfB
Banned For Rules Violations
Can you give us any more info about time it took, maybe pix, anything we need to know when doing this, tools, etc.?
Old Jun 28, 2002 | 09:08 AM
JohnnyLightning Store
The store states that they aren't priced yet and not in stock, but you can give him a call. He has them available, just confirming pricing depending on powdercoating, etc.
Old Jun 28, 2002 | 09:16 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
'Bama Bubba,
stand by for further info....work in progress.
Bob
Old Jun 28, 2002 | 09:33 AM
tommylightning's Avatar
I also have the JLP traction bars. Just installed them yesterday. They are very nice quality and very heavy duty. The brackets were made just for the Lightning. I will post my findings on Monday. Will be using them tonight and all weekend at ModMotorShootout!
Here are some pics! I painted the bars silver, will need to go over them again.
Old Jul 14, 2002 | 12:41 PM
JeffsLightning's Avatar
Tommy do you have any more pics.?
Old Jul 14, 2002 | 12:58 PM
LightningTruck's Avatar
How about the results. Do these things work? Are those adju$table shocks required?
Old Jul 15, 2002 | 09:02 AM
Let me know what you would like to see and I will take a pic. As far as performance. I still need to test them. So far they seem to work well but can not tell for sure as I had a bad head gasket. I am all fixed and ready to test this weekend @ Englishtown.
Old Jul 15, 2002 | 03:07 PM
I have some results. An exellent 60' for me after my motor work and larger pulley was in the 1.8 range, normally around 1.9-2.1. I installed the JLP bars and had consistant 1.6x 60's at the mod shootout. They were 1.61, 1.62, and I believe 1.64 respectively.
Old Jul 15, 2002 | 04:20 PM
Tommy how some shots of the brackets and how much the bar clears the exhaust pipes....
Old Jul 15, 2002 | 04:22 PM
I have a Bassani exhaust and 1.5/2" drop and it clears the exhaust well.
Old Jul 16, 2002 | 03:09 PM
blackjack's Avatar
Lightbulb Few questions...
Couple questions for you:
1. Before you installed the traction bars, what tires were you running on to get 1.8 60 fts.???
2. Were you running at the same track with the same tires both before and after the traction bars were installed??
3. If so, were track and weather conditions similiar???
4. What size pulley(s) are you running on your truck??
5. Do you have a higher stall torque converter??
6. Are you running Nitrous??
The reason I ask these questions is because something is not adding up....gaining 0.2 seconds in your 60 fts??? Because of traction bars???
Scott
Old Jul 16, 2002 | 03:19 PM
Same track, same tires, hotter temps, more boost. Yes, with good traction more boost will give you better 60's. However, more boost will also give less traction. Therefore, more boost and traction bars gave me better 60's.
Old Jul 16, 2002 | 03:28 PM
Don's Bolt's Avatar
And the confidance to put the hammer down and know that the driveshaft will stay connected.
Congratts on the new 60 foot times.
Old Jul 16, 2002 | 08:45 PM
blackjack's Avatar
Yes....
More Boost and better traction will yield better acceleration....how MUCH more boost were you running???? I have run 1.84 60 fts at Cecil with NO traction modifications(i.e Traction Bars or Shocks) with a 4 lb lower pulley with Stock exhaust. I now have the 12 way Adjustable QA1 shocks installed since then. How much would adding traction Bars help with all things being equal??
