Should I wax the bed of the truck before installing the Bedrug?
Have you considered the spray in bedliner stuff prior to installation?
Adds an extra layer of protection if the BedRug was to shift and some sound deadening. The velcro sticks well to it.
Originally posted by captainoblivious
You could always install the bedrug, pull it out the wax it the bed. The velcro would already be attached so you won't have to worry about it not sticking.
i wouldnt put in and take out the bedrug all that often. it seems that the velcro itself holds better than the glue. when trying to un-velcro some of the points on mine, some of the "hooks" on the velcro began to break off.
What are you waxing it with? If you use carnuba it will not last. It will melt around 140 F .
If you use a polymer sealent you would be better off. It would melt at 400 F which your bed would never reach.
Either way both will wear off after a while, and you will halfto re-wax your bed........
www.autopia-carport.com
I didn't wax it, and I didn't have the energy or will to run around in the heat and find alcohol. (the bed was about 100* when I installed) Then after wash/dry I sprayed windex on a paper towel, and wiped down the area where the 2 long strips go. They're the important ones anyway. It's not really a huge issue unless you're going to drive around with your tonneau cover off.
I honestly think that a spray in liner underneath a bedrug is a huge waste. Sounds more like bad planning than extra sound deadening
No offense tampa
No offense tampa
Five years from now when you pull the bedrug off and find that the back of the velcro rubbed through the paint and rusted, I don't want to hear anything...
I actually did it because(*gulp*) I had a couple of scratches on the bed from the moving stuff that went through the paint.
I could have touched up each scratch, but the spray-in took care of all of it.
Had nothing to do with poor planning, I assure you...(no offense taken).
Rich
Rich
Don't get me wrong, I'd love to have both, but I honestly don't think the 600 bux it wil cost me up here is worth it for something that I'll see once or twice for the duration of my ownership of the vehicle. I honestly never plan to haul much more than the occasional buddy's couch
