Alignment Specs
Old Jun 16, 2002 | 11:05 PM
J15BIG's Avatar
Alignment Specs
I did a search and came up with these:
Lightning specs:
L.H. Caster: 6.9, +/- 1.0 Deg.
R.H. Caster: 7.4, +/- 1.0 Deg.
L.H. Camber: -0.5, +/- 0.7 Deg.
R.H. Camber: -0.5, +/- 0.7 Deg.
L.H. Toe: -0.05, +/- 0.15
R.H. Toe: -0.05, +/- 0.15
Lightning Owner preferred:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Base F150: (tolerances same as above)
L.H. Caster: 6.2
Shorty:
R.H. Caster: 6.7
L.H. Camber: -0.3
R.H. Camber: -0.3
L.H. Toe: 0.03
R.H. Toe: 0.03
Lightning Owner autocross preferred specs:
LH Camber -0.7
RH Camber -0.7
LH Toe OUT 0.05
RH Toe OUT 0.05
Which one should I choose? I guess the owner preferred one? I just had the rest of my ground force 1/2 kit installed and am goin to have it aligned. Are there any other ones?
Old Jun 16, 2002 | 11:32 PM
SLVRLTNG's Avatar
Joe,
you may want to wait til your motor is in...I think the weight will change alignent...........
Old Jun 16, 2002 | 11:38 PM
J15BIG's Avatar
yeah, they are not going to do it untill the the truck is ready to go, meaning the motor and tranny is in. but thanks for the advice anyway!
