Electric fan question
Old Jun 15, 2002 | 04:36 PM
Dan SS2471's Avatar
My '01 L has the JDM electric fan kit. It also has the optional toggle switch under the hood.
I just went for my first cruise around town and the fan seemed to be on a lot when sitting in traffic. The temperature is pretty cool here in NJ today, so I just wanted to make sure that's ok.
Also, I did a quick hot-lap on RT 1 and pulled in the garage right afterwards. The fan was on. I turned the truck off while it was still on rather than sit at idle and wait for it to turn off before shutting off the engine. That ok? Or should I wait for the fan to do it's thing cooling the intercooler and then shut off the engine?
Thanks in advance...
Dan
Old Jun 15, 2002 | 06:57 PM
Silver-Bolt's Avatar
Dan,
You should be fine. Your fan probably also has the a/c option. The a/c option kicks the fan on every time the a/c pump runs. If your heating controls are anywhere but in the off or vent position the e-fan will kick on. No problem turning the truck off with the fan running.
Old Jun 15, 2002 | 11:52 PM
Dan SS2471's Avatar
Originally posted by Silver-Bolt
Dan,
Thanks for the info!
Dan
Old Jun 16, 2002 | 02:53 AM
red00Lightning's Avatar
Dan,
Except it's running on battery alone...on a weak battery it would sure suck to drain the battery all the way down
--wes
