Flasher Relay
Old Jun 8, 2002 | 11:43 AM
Mister SVT's Avatar
Question Flasher Relay
Does anyone have any clues as to where this is located and exactly which on it is on the Gen 2's?? I added some LED bulbs to my truck and need to replace mine with a variable load flasher so they work correctly. I tried the 4 relays under the dash in the fuse panel as instructed by local dealer but that didnt do anything for me....even tried removing them with signal on and didnt do squat. I am not as brave to try this with the several in the power block under the hood.
Thanks!!
Eric
PS.... I also contacted SVT and the were no help as were several parts stores or another dealership here in OKC.
Old Jun 8, 2002 | 04:09 PM
IXLR8's Avatar
I have the same problem. I only replaced my tail lamps with LED units from LEDtronics. I think the turn signal flasher is intergrated into the hazzard relay. When I use either the clicking comes from the same module under the dash above the accelerator pedal. Although my directional signals blink fast the hazzards are at the normal blink rate.
I have tried also to get a flasher modual that would not be fooled by the lower amp draw of the LEDs but with out success. I was thinking of 2 possible fixes.
1st one wire stock sockets in parallel behind housings and paint bulbs black.
2nd one wire in a resistor with the same impedance and wattage as the bulbs.
Old Jun 8, 2002 | 08:08 PM
Mister SVT's Avatar
Hmmmmm...havent thought to check the rate of emergencies as that would make sense. You can buy what is called a load equalizer that splices into the wiring. I got my bulbs from jamstrait and they told me I would need a equalizer for each side at the rear (tail lights) and that would correct it. They are like $15 a piece but I didnt want to splice into the factory wiring if I dont have too.
Eric
Old Jun 9, 2002 | 08:36 PM
IXLR8's Avatar
load balancer sounds a lot like the resistor idea I had. $30 for a few resistors sounds extreme maybe its something different. Did you do the front turn signals also? Well let me know how you make out which ever route you take. I really don't have the time to play with mine currently. I spent $50 a piece for the bulbs so another $30 won't break me. I did check the trailer hitch wiring to see if I could use that in some way but it appears to use a separate relay. So an additional load at that point would be useless. I dont have a problem tapping into the factory harness. I would solder and heat shrink any splices. I have seen too may of those crimp type connections go bad.
Old Jun 9, 2002 | 08:52 PM
LightningTuner's Avatar
There is an integrated flasher/hazzard relay block behind the dash. Both turn signals and hazzards work off it. The only problem I see with swapping it for a different one is what it physically looks like. There may not be an aftermarket one to use. Hope this helps.
Old Jun 10, 2002 | 01:14 PM
NOSTROMO
Guest
Posts: n/a
www.hzengineering.com
They have load resistors blocks which are used for LED swaps.
