E-FAN for $175!!!!!
Old Jun 6, 2002 | 04:39 PM
99BlkLitng's Avatar
I would like the info and pics also. damlgarr@hotmail.com
Later
Damon
Old Jun 6, 2002 | 04:48 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Exclamation
FYI, check out the various "L-related sites" It's out there.
more gratuitous imagery...
Old Jun 6, 2002 | 05:05 PM
red00Lightning's Avatar
Originally posted by soap
Tim I will take pictures tonight and hook you up.
--Joe
Hmm...looks like a lot of people are interested....I certainly am.
Could you post the pics and brief how to here? If not can you shoot it to my email address as well please?
red00lightning@lycos.com
Old Jun 6, 2002 | 05:07 PM
Weedo's Avatar
Ahhhh, "various sites". I think that's at www.variousLsites.com right??
Old Jun 6, 2002 | 05:19 PM
VINNIE's Avatar
Add one more to the list
Can you send me info and pics also.
www.01vinman@optonline.net
VINNIE
Old Jun 6, 2002 | 05:33 PM
"Just the other day while pondering an electric fan installation and losing concentration, I nearly severed off my (BLANK)...or something
Old Jun 6, 2002 | 05:55 PM
Fast Gator's Avatar
Hey Soap
Why not just post the pics here, so the whole Lightning family can view! Yeah, Iam interested too
Old Jun 6, 2002 | 11:09 PM
soap's Avatar
OK bear with me this is gonna take a few posts. I have alot of pics so if I missed something ask and I may have it.
Here are the brackets I made out of steel stock it was a 3' piece by 5/8" and I cut it into pieces and bent them to fit. Tapped and drilled them, then painted them flat black.
--Joe
Old Jun 6, 2002 | 11:10 PM
soap's Avatar
Here are some close ups of the brackets from under the truck (only way to see them)
--Joe
Old Jun 6, 2002 | 11:11 PM
soap's Avatar
Here are pics of the hardware I used. I just went to Lowes and got a bag of 1/4" 20 aluminum bolts and self locking nuts. The first 2 pics are showing the bottom mount. It is just drilled through the shield on the fan then through the bottom of the shroud. The angles line up perfectly when you lay the fan in the shroud. The last picture shows the top of the stock shroud and all you can see from the engine compartment.
--Joe
Old Jun 6, 2002 | 11:12 PM
soap's Avatar
Here is a shot of the switch mounted under the dash. Also the relay mounted to the firewall and the inline fuse to the left of it. I used all 30amp "stuff" i.e. switch, relay, fuse, wiring.
--Joe
Old Jun 6, 2002 | 11:18 PM
soap's Avatar
Final thing, probably most important.
When you get the fan you will probably be like WTF!!!!! Since it is made to fit another automobile it has alot of extra plastic outside the fan guard. I used an air cut off saw and trimmed it all off then sanded the entire thing down until it was smooth. This ensured it would fit the way I wanted it (like up against the bottom of the stock shroud) and look very clean when done.
Hope this helps someone...LOL
--Joe
Old Jun 7, 2002 | 12:54 AM
tallimeca's Avatar
what about the wiring
what about the wiring harness and where to hook everything up.....where did you come up with that?
Old Jun 7, 2002 | 08:08 AM
soap's Avatar
Re: what about the wiring
I came up with it in my head........not rocket science really. Power comes from the solenoid goes through the fuse to the switch under the dash then through the relay to the fans. It is wired to a toggle switch......I wanted to be able to turn it on/off when ever I want, so I did not have to mess with all the A/C controls, water temp controls etc. I am the only one who drives my truck so I never worry about someone else forgetting to turn them on when it gets driven.
--Joe
Old Jun 7, 2002 | 07:49 PM
tallimeca's Avatar
rocket science
yeah, it's not rocket science, but i'd drather have it working with the a/c and temp sensor as well as the toggle. That's how these tuners are getting what they get for these kits. You could do the wiring harness as well, which isn't rocket science but i'd drather have it look good, and wiring isn't my cup of tea.
