Well First Time Ever at the Track.....
I finally took the ole' L out for a run the other night. I caught up with a few friends from the Corral.net and went out to the track in MS. Well first off they wouldn't allow you to drive around the water box, which I don't guess was good for me on street tires. I tried just turning 'em over for a second to clean and dry the tires off. I ended up only cutting a 2.29 60' (pretty embarassed about that)with the truck getting REALLY loose on the 1-2 shift... ran a 13.5 at 104.6. That was full weight and a little over a 1/4 tank of gas. Any guess on was she will run if I can get that 60' down?
well that was my first experience at the 1/4
All in all I had a f'n blast! I am not dissapointed at all in the truck, just a little bit in the driver
P.S it was VERY humid and about 80 degrees
80 degrees, humid enough that I could write my name on the truck. The track was VERY slick as I posted earlier.
I will be going back in 2 weeks, I have to go home this coming weekend (HELL YEAH)!!!
That's a really good time considering the 60' and the weather conditions. If you hook up and get a 2.0 60' I see a 13.2 in your future.....
At that same MPH, I drove a 13.2xx with a 2.1 60'. If you managed a 1.9 or 1.8 60' (certainly do-able with low tire PSI or stickier tires) you could conceivably knock down a 13.0. (I didn't hit 13.0 until I was MPHing at around 107...)
Originally posted by qball2439
hehe Thanks yall! I am gonna see if I can get that 60' down a bit and get into the low 13's knockin on 12's
I guess I will go get some DR's or those new hoosiers and see if I can get that 60' down.
