Need a lil help
Old May 27, 2002 | 11:38 AM
BOOST's Avatar
Need a lil help
Ok so my wheels came in and the wrong wheel lugs were sent with them. They sent a 12mm x 1.75. So i need to go out and get the right ones. I am not patient so I am just gonna buy them myself. What I need to know is the right size. I have been told both a 14 and a 15 mm. But i also need to know the thread pitch etc. Anyone out there know? Thanks for you r help.
Old May 27, 2002 | 11:42 AM
LightningTuner's Avatar
You need 14mm x 2.0 pitch.
Old May 27, 2002 | 11:43 AM
BOOST's Avatar
Thank you very much. I am assuming that it is the same for all year models. I have an 02.
Old May 27, 2002 | 12:05 PM
Yes, only 99s use the 12mm studs. The 00-up all use 14mm. The rims will fit all years however.
Old May 27, 2002 | 01:06 PM
Silver-Bolt's Avatar
If they are for slicks be sure to get the open ended nuts. Tech won't pass acorn type nuts. M14-2.0 (14mm) is correct.
