Throttlebody=reburn??
Old May 22, 2002 | 08:28 PM
Twinturbo Ranger's Avatar
Do you have to get a reburn on a TB install? I just can't get mine to idle low enough no matter what I do. Thanks Mike
Old May 22, 2002 | 09:46 PM
Silver-Bolt's Avatar
Mike,
No re-burn. If backing the idle screw out does not do it you may have to adjust the TPS.
Old May 22, 2002 | 09:53 PM
I tried both,but I did not adjust the TPS the correct way I'll fool with it tomorrow. I'm very pleased with the response and power I got from it. Thanks for the info.
Old May 23, 2002 | 12:57 AM
RA6870's Avatar
Post GO HERE YOU MIGHT NEED TO ADJUST IT!!
https://www.f150online.com/forums/sh...threadid=66431
Hope this helps!!
Old May 23, 2002 | 01:18 AM
Jay Lincoln's Avatar
Just got done working on my new Accufab. Set the idle voltage on the TPS at .92 VDC. It will allow a range up to 4.57 VDC at full throttle. All is good, except the throttle really sticks closed.
Adjusted the stop 4 (!) turns to stop the sticking. There is not enough adjustment in the TPS, or the Idle Air system to overcome this much opening. I even "finessed" the TPS so there would be more adjustment. No Bueno.
Looks like this one goes back.
Old May 23, 2002 | 08:13 AM
jarmstro's Avatar
Post
We always had to elongate the holes on our Mustangs where the screws are on the TPS.
Take a rattail file or drill bit make the holes bigger. You will have plenty of adjustment then.
I had to elongatge the holes on my BaBolt TB, however on my Accufab didn't have any problems.
Old May 23, 2002 | 10:54 AM
John, I elongated the holes about .030". That was enough to get the idle back down, eventually to abound 850 RPM.
I think the problem is that I had to open the throttle blade so much (4 turns on the set screw), the IAS cannot accomodate the large volume of air entering through the throttle body. I think it's just a throttle plate misalignment.
I'll call Accufab this morning.
Thanks for the suggestions.
