removing tint.........
Old May 21, 2002 | 10:24 PM
blowntruck's Avatar
Unhappy removing tint.........
Anyone know how? Ive never had to remove tint so I have no idea where to begin or what to do. Any help, tips would help. Thanks
Old May 21, 2002 | 10:31 PM
jmlay's Avatar
Use a razor blade to get one corner started. Pull it back at a sharp angle so the glue comes with it. Spray the glass with Windex and let it soak. Take the razor blade and scrape the remaining glue. One last scrub with Windex and you should be clean.
Be careful with the razor blade you can scratch the window.
Old May 21, 2002 | 10:43 PM
nlsplight1's Avatar
if it is a good quality tint you can use a heat gun,and it will come right off with no messy glue.
Old May 21, 2002 | 10:47 PM
blowntruck's Avatar
Heat gun, and heat from what side? the outside or right on the tint inside? Thanks, i might just have to do the the razor thing. Thanks
