PSP 4-way chip
Old May 16, 2002 | 01:23 AM
Ky.Lightning's Avatar
Question PSP 4-way chip
I have a Race setting on my PSP chip. What kind of gas or octane boost do I need to run with this setting?
Old May 16, 2002 | 01:43 AM
J15BIG's Avatar
check with sal but i would use 100 or more.
Old May 16, 2002 | 02:30 AM
clonetek's Avatar
it depends on what you told sal to set it at... my race setting is with pump grade 93 octane. the local track doesn't sell unleaded.
Old May 16, 2002 | 09:25 AM
CHIKIN1's Avatar
My PSP "Race" setting requires 98 octane minimum!!! There should have been an install instructions sheet w/the chip, this sheet also tells which setting is which and if the setting requires special octane...But you better E-mail or call Sal to make sure!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
424HP/528ft.lbs @ Normal Temp. w/o N2O
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
Old May 16, 2002 | 12:47 PM
LIGHTNINROD's Avatar
Ky:
Sal doesn't recommend "octane boosters". IMHO, they are almost useless.
Most tracks will have an unleaded 100 octane gas available for you to buy. Sal likes, and I use Torco Unleaded Accelerator which is a 'rece gas concentrate', not an oct. booster. See wwwtorcoracingfuels.com No I'm not a dist.
Dan
Old May 16, 2002 | 12:50 PM
RTKILLA's Avatar
Mines set at 100 octane, but I would ask sal too.
the tolulene is working great for me too, 1.5 gallons of that and 3.5 gallons of 100 octance and you got a nice mixture for some serious racing!
Old May 16, 2002 | 01:01 PM
Silver_2000's Avatar
Re: Ky:
Dan
Octane Boosters dont work but everybody sells them...
Including Torco http://www.torcoracefuels.com/Wizard.htm
Doesnt make any sense...
Doug
