Denso IT-24
Old May 15, 2002 | 08:24 PM
Autothrottle's Avatar
Question Denso IT-24
Whats the gap for these plugs?
Thx
Old May 15, 2002 | 08:30 PM
beefcake2002L's Avatar
Registered User
I do believe that would be .040. Good luck.
Old May 15, 2002 | 11:38 PM
I found this on thier site. Just so you know.
IT20 5326 14 .708" 16 1.1 0.044
IT22 5327 14 .708" 16 1.1 0.044
IT24 5328 14 .708" 16 0.8 0.032
Old May 16, 2002 | 10:24 AM
J.D. Blackwell's Avatar
I believe those maybe too cold of a plug to run.
Old Jul 24, 2002 | 10:20 AM
easterisland's Avatar
So, the IT-24 should be gapped at .040 or .032?
Old Jul 24, 2002 | 10:34 AM
Odin's Wrath's Avatar
LightningTuner
Depending on who you ask, you'll get different suggested gaps for different combos, but here is what I suggest:
Stock boost to +2psi using IT20s- .038-.042
+2psi to +4psi using IT20s- .036-.040
+4psi to +6psi using IT24s- .032-.038
over +6psi using IT24s- .030-.034
If you are running nitrous, subtract .002 from the above.
Remember that as you add boost, you increase cylinder pressure. As cylinder pressure goes up, it's harder for the spark to jump the gap. This is why we suggest to lower the gap, when you increase boost. Same goes for nitrous, more oxygen, more cylinder pressure.
On my truck, I run 18psi and 150 shot and my gap is .028. Anything over that, and the truck breaks up at high rpms.
Old Jul 24, 2002 | 10:54 AM
