Which Denso's replace the TR6's?
Old May 15, 2002 | 07:31 AM
Skank Dog's Avatar
I was wanting to change to Denso's but not sure which one's are a direct replacement for the TR6. With the 4# lower and metco upper Im running, I need the heat range of the TR6 plugs Im running now to keep detonation at bay. Ive seen It20''s,22's,24's etc. Any help GREATLY appreciated!
Old May 15, 2002 | 07:41 AM
LIGHTNINROD's Avatar
I have a 5 lb lower which is close to your total boost. Sal recommended IT24s for mine.
Dan
Old May 15, 2002 | 07:49 AM
RA6870's Avatar
Post HERE IS A GOOD CROSS REFRENCE GUIDE
http://www.iridiumpower.com/crossref...16&action.y=12
Old May 15, 2002 | 03:14 PM
usahooters's Avatar
If your having detonation problems get a reburn or run a higher octane fuel, its not the plugs. I run a 6# pulley with NGK TR5's and have no problems at all. I also run 100 octane mixed fuel. The only reason you needed to get rid of the stock plugs is because the platinum plugs hold heat like a Cat. converter does.
