RTKILLA*****Question about radio.
I saw the pic of your stereo setup with the deck and equalizer(or whatever it is) and im intrested in doin the same thing. How did you mount both of them? Is that a custom job or can I get the kit somewhere?
thanks
thanks
Custom baby!
the lower piece is a mini disc changer/player. I bolted the two units together and then figured out ohow much of the hole I had to cut out to fit it in there and I slide it into place and strap it in and made a custom plexi glass cover for it. You don't have to cut the outside trim at all, but the inside will need to be cut up to fit a double din setup. Once you do this though, you can't go back that easy.
