oil fill on lightning
Old May 13, 2002 | 06:56 PM
kl;uxman45's Avatar
Question oil fill on lightning
is this right?i changed my oil on my 2001 lightning and it took a new oil filter and 7 qts of oil.and it is on the top hole on the dip stick.right on the full mark.
Old May 13, 2002 | 07:03 PM
E-LO's Avatar
MIne took 6 qts
Old May 13, 2002 | 07:18 PM
Thor01's Avatar
kl;uxman45,
I would drain 1.5 quarts out before driving it. You do not have to run the engines at the full mark. 1/2 or 3/4 mark on the stick at the most. 7 is way to much.
Old May 13, 2002 | 08:05 PM
LIGHTNINROD's Avatar
A full crankcase is 6 qts. This usually registers at about the 1/2-way mark on the dipstick. 7 qts is too much and some of that 'extra' oil will end up being forced into the intake adaptor, throttle body, and rubber intake boot area. After you've gone into a boost situation a time or two, loosen the clamp at the th. body/rubber boot and slide the boot down and off. There will probably be oil seen in that area.
Dan
Old May 13, 2002 | 11:35 PM
kl;uxman45's Avatar
in take area
what rubber hose do ya remove to get the oil out?ya got a pic?is the throttle body the one with the butterfly in it?when ya open it up?the one where the air filter boot that is connected to the maf is?
Old May 14, 2002 | 08:01 AM
Re: in take area
Sorry, I don't have any pics but you're in the right area. I f you remove the boot completely, be sure to get those two tubes back in their respective 'holes' securely.
Dan
Old May 14, 2002 | 08:26 AM
LatemodelRacer2's Avatar
i was told between 5 1/2 to 6. Just my .02
