what oil to use?
Old May 8, 2002 | 09:04 PM
teblmm's Avatar
what oil to use?
i have an 01 L and i was just wondering what oil is everyone using.
Old May 8, 2002 | 09:10 PM
SLICK0478's Avatar
Talking I use
I use Mobile one 5-30w full synthetic since 500 miles and no problems or noises to report and I'm @ 2500miles now. I am gonna change it again this week same stuff W/ ford filter
SLick
'01ArrestMeRed's Avatar
5w/30 and a Motorcraft FL820S Filter. I started her on this at 10,000 miles. I now have 25,000 miles. Never made any unusual noises, ever.
Old May 8, 2002 | 10:38 PM
Don's Bolt's Avatar
Same with me
10,000 miles I switched to 5w-30 mobil one.
Old May 9, 2002 | 08:25 AM
LIGHTNINROD's Avatar
There is ONLY ONE oil worthy of my Lightning's engine. Don't even think of any other for yours. You must use the oil that is listed in my sig.
I'm just kidding guys!
There are several, high quality, synthetic oils--Amsoil, Mobil 1, Redline, and Royal Purple(their 'racing' oil is a full synthetic while their 'street' oil is a blend). My point is, get a synthetic oil. Its protection(it does not 'drain' off of the bearing and wear-surfaces like dino oil does so dry starts are reduced) and its ability to not breakdown in ultra-high temps are just two reasons to use a synthetic.
I started using RP at 4,000 miles(now have 27,300) and I use the K&N Gold oil filter which is a good filter and it has a 1" 'nut' on the bottom for easier removal.
Dan
Old May 9, 2002 | 08:36 AM
dboat's Avatar
I use Mobil 1 and a Mobil 1 filter. Most use Mobil 1 because its a good product and easier to find than the rest.. Plus if you are like me, I'd rather someone else change the oil, then you are pretty much limited to Mobil 1 if you are going to use a synthetic.
dboat
Old May 9, 2002 | 10:28 AM
RTKILLA's Avatar
just hit 38 thousand and its been mobile 1 oil and a motorcraft 820S oil filter since the first oil change.
Old May 9, 2002 | 10:54 AM
jrcase's Avatar
Be advised that the 2001's call for 5w-20 not 5w-30. Mobil One will be releasing the 5w-20 soon.
Old May 9, 2002 | 11:15 AM
2Cool's Avatar
I use Amsoil 5W-30, and will do so regardless of the manufacturer specs. It gets way too warm down here in FL for me not to want a bit more viscosity under higher temps. -20 helps Ford to improve their corporate average fuel economy ratings...
Old May 9, 2002 | 11:22 AM
FastAsL's Avatar
mobile 1 5w-30 synthetic and motorcraft 820s filter since 5000 miles no problems. i also know a lot of people who use royal purple and they will swear by it. i just dont like to keep switching oils.
Old May 9, 2002 | 11:29 AM
snoopy's Avatar
Really??? How do you know this? When?
Old May 9, 2002 | 11:31 AM
slapshot's Avatar
I use Penziol 5w-30 now with the Ford filter. On the next oil change, I am changing to synthetic, probably Mobil 1.
Old May 9, 2002 | 11:45 AM
Marc Carpenter's Avatar
Castrol 10-30 synthetic and Fram PH-2. No trouble yet.
Yea, Yea, I know Fram is no good, but they and the oil are free..
Marc
Old May 9, 2002 | 12:00 PM
RA6870's Avatar
Thumbs up ONLY THE BEST!!!!!!!!!!
http://www.amsoil.vze.com/
I Have been runing it for 20,000 miles without a single problem. I think it runs better with it. I have tried them all and Amsoil is the best I have tried!! Just my .02 cents worth Good Luck!!!
Old May 9, 2002 | 01:32 PM
95 Saleen S351's Avatar
I use snake oil
