Cams --------- Again
Old May 8, 2002 | 02:43 AM
J15BIG's Avatar
I read this thread about cams and got a lot of info. But im wondering if any of the guys that had cams on order installed them and got on a dyno or went to track. And you guys that do have them on order or have them, can you give me the specs?
thanks
Old May 8, 2002 | 11:41 AM
TimBurntire's Avatar
cams
specs for Crane regrinds.
lift: Intake 278 @valve 500
Exhaust 290 @valve 522
Rocker arm ratio: 1.80
Lifts are based on zero lash and theoretical rocker arm ratios
Cam timing: Intake Opens @ .006 5.0 ABDC
closes @ 70.0 BTDC ABDC
Exhaust Opens @ 63.0 BBDC
closes @20.0 ATDC
Duration Intake 255
Exhaust 263
Loads:
Minimum rpm 2500
Maximum rpm 6000
Valve float 6500 (with original springs)
Timing @.050
Intake opens 12.0 ATDC closes 43.0 ABDC 117 duration ATDC 211
Exhaust opens 46.0 BBDC closes 7.0 BTDC 117 duration BTDC 219
This info is directly off of the Crane build sheet
PN 02106 Grind # HR-211/500-2S-17 0A (LEFT)
PN 02107 Grind # HR-211/500-2S-17 0A (RIGHT)
Mainly these cams allow a higher rpm range than the oe cams along with a much steadier HP across the rpm range.
Less torque at the bottom end, but a more sustained range of both HP and torque across the entire rpm range.
Old May 8, 2002 | 11:52 AM
Jay Lincoln's Avatar
Check with Sig Erson. I believe that they are making new billet cams. They will allow you to run mor lift, w/o upsetting the valve train geometry.
Old May 8, 2002 | 12:12 PM
soap's Avatar
Pretty sure Comp Cams makes mod motor cams. Give them a call.
--Joe
Old May 8, 2002 | 03:33 PM
J15BIG's Avatar
ttt
Anyone have more info on cams?
Jay,
Do you have a web site or phone # for Sig Erson?
Old May 8, 2002 | 04:03 PM
Lightning Boy's Avatar
I know Sal has re-grins, and may or may not have billet cams (if not he is working on them).
Old May 8, 2002 | 05:12 PM
J15BIG's Avatar
how much do you guys think a shop would charge me for installing bigger valves and insalling new cams? ball park.
