Shes going under the knife June 4!!!
I made my appt at my local shop to have my engine put in. They might put new valves in as well but I havent decided on those yet. Hopefully sals blower will be ready by then but well see. If not im goin to have to put the stocker on for a while. I just wanted to update you all because i know some of you are curious. After I get the engine in, next will be F/Ts monster box then Longtubes. And after all that ill start with cosmetic stuff like rims, hood, etc...
Shes coming along good....
later
later
Who did your Engine???
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
410HP/503ft.lbs @ Normal Temp. w/o N2O
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
JL 3# Lower Pulley
JDM Cold Air
JDM Boost Bypass
JDM Cobra R pump
JDM Eletric Fan
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Be prepared to wait on your motor rebuild as mine was supposed to take three weeks and is already been three months. The lastest set back being a batch of defective valve springs that need to be remade. The actual pistons,rods and balancing took less than three weeks.
If I had it to do over again.....I would order a built block from one of the tuners.Now after all this time ,i only hope i can remember were everything go's when i get it back
i was assured that my engine would be here before then. i have been waiting at least a month now and trust sal to stick to his word. hopefully my shortblock will be here before then.
