JDM Billet fuel door install.
Hey guys,
Does anyone have a detailed install on this? I just ordered it and was wondering if the install is tricky. Anything unusual I need or any unseen problems, are the directions good? Thanx.
Gavin
Gavin
Remove the stock fuel door by removing the 2 screws to the left side near the hinge. Remove the 2 rubber stops from the other side, fold door in a little ways so that you can remove the hinge from the hole. Next take the JDM cap and set it p to make sure everything lines up properly and that the bolt holes match. They should. SO.... Take the new door and the two screws and lock nuts and place the door in place and tighten down the screws till the door becomes flush with the side of the truck. It might be necessary for you to use some small washers behind the fuel door ring to make sure that it stays flush to the body of the truck.
Sorry If I missed anything, it's been awhile since I did mine.
Good Luck and if you need any more help feel free to e-mail me.
Later...
Bruce
BCLeymeister@aol.com
Later...
Bruce
