Disappointing dyno #'s
Old Apr 26, 2002 | 08:27 PM
djc cobra's Avatar
Guys, do these numbers sound right to you?
stock 01, bout 56 deg, rained earlier in the day, 91 oct cal gas
first pull
peak hp - 308 @4400 rpm
peak tq - 371 @ 4200
second pull
peak hp - 311@4400
peak tq - 375@4100
dropped in k&n
peak hp - 317#4800
peak tq - 386@3800
seems low to me
Old Apr 26, 2002 | 08:35 PM
Dick 4's Avatar
A bit low
How many miles on your L?
Old Apr 26, 2002 | 08:58 PM
djc cobra's Avatar
7500
4 gal of gas in the tank too at the time
Old Apr 26, 2002 | 09:04 PM
JeffsLightning's Avatar
Yep you look at least 20/30 HP low stock. Those numbers are corrected right?
Old Apr 27, 2002 | 04:47 AM
djc cobra's Avatar
im not sure. how do i tell? call and ask?
Old Apr 27, 2002 | 09:45 AM
Fast Gator's Avatar
They do seem a bit low, 330/340 hp are about average. 7500 miles, you would think it's broken-in by now.
Old Apr 27, 2002 | 10:28 AM
Odin's Wrath's Avatar
It could just be the dyno your using. The one I go to has never dynoed a stock L over 310 hp. For the mods I have, I am dynoing lower than guys with less done to their trucks. I keep using the same guy so that I can tell if what I do to my vehicle is helping me or not.
Old Apr 27, 2002 | 11:19 AM
CHIKIN1's Avatar
Was it a DynoJet or Mustang Dyno, cuz if it was a Mustang Dyno
( I have my truck dynoed on a mustang dyno ) then the numbers are gonna be lower...I would say 15-25 HP lower...or maybe your truck sucks j/k
Take it to the track and let that be your dyno...stock 1/8th mi. MPH should be right at 80mph and less than 77MPH I would then say your truck is down on power!!!
Or if you have another dyno close to you give it a try!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
410HP/503ft.lbs @ Normal Temp. w/o N2O
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
Old Apr 27, 2002 | 05:04 PM
tliss's Avatar
On a Dynojet you should be pulling between 340 and 350 RWHP on a '01. Mine stock was at 346.8.
[img]**************************************/tliss/34897.jpg[/img]
I've got a feww goodies now and just ran 391.4.
[img]**************************************/tliss/77436.jpg[/img]
Tom
Old Apr 27, 2002 | 05:06 PM
tliss's Avatar
OK, so the image posting doesn't want to work for me. Check out the graphs at
http://www.f150world.com/tliss
if interested.
Tom
Old Apr 27, 2002 | 06:30 PM
djc cobra's Avatar
it was done on a dynojet in san diego.
i ran the 1/4 at 13.9 @101 last month.. do you think they could have just dyno's it incorrectly? is that possible?
Old Apr 27, 2002 | 07:13 PM
My poor numbers were from a dynojet, also. This particular dyno consistently turns out lower than expected numbers. The manufacturer of the dyno isn't the only factor involved in number variances. Lack of regular maintenance and differences in calibration could explain the changes from one dyno to another, also. I'm sure there are other factors, that I'm not aware of, as well. Time slips are a better measure of your actual performance. If you ran a 13.9 @ 101 mph, that's close to what you should be running stock. I wouldn't worry about it. Enjoy your truck.
