Help, I ran over a screw
Need some advice, I just found a drywall screw in my back rear tire, when I loosened it, air started coming out. Is it ok to take it to the tire shop and have them put a patch on it? Or are the F1's different? Thanks.
i just had a 1/4 ince screw removed from my rear tire. they patched it and i have easily gone over 120 since it got done, and no problems.
everyone else, have u ever seen the "patch" they put on the inside of the tire? they might as well put a kevlar vest on there also, there is no-way that thing is coming off or anything else is going through it.
I asked Dreamin the same question a long time ago after a bolt punctured my tread. You can use two patches and still maintain the speed rating. But, would I risk running 140+ for thirty minutes? No. I would run a road course though. On the other hand, if you are running a chip tuned for drag racing, your valves will tulip from the high speed long before the tires will cause problems.
Spike
Spike
3 out of my 4 tires have a patch in them from a screw and/or drillbit. This never happens to me in a beater with cheap @$$ tires, but in a nice car.... GRRR!
I'm just waiting on my one pristine tire to pick something up. I always get it in a rear tire too, how about you guys?
FYI, I've run patches on race tires on a road race course before, no issues....
Um... with all this discussion about nails and screws in tires, i walked out and checked my own tires. Noticed a drywall screw in one of my rear tires too! It's at a 45 degree angle, going into the base of a tread block. I'm not sure if it has actually penetrated the plies beneath, or just the rubber tread block because of the angle. I can't tell how deep it is either because the head of the screw has sorta disintegrated.
My tire pressure is the same in each tire and I have driven it at 80 MPH without incident. The screw could have been there for months. maybe since new. If it's not losing air, should I leave it? Or am I playing with fire?
My tire pressure is the same in each tire and I have driven it at 80 MPH without incident. If it's not losing air, should I leave it? Or am I playing with fire?
Ben,
Personally I would leave it for a while and keep an eye on it. I don't think it'll blow out of there all at once..If after a while you can tell how deep it is and it's really in there(not just on the surface), then I would have it patched.
When I bought my truck it had a leaky tire, the dealer patched it for me and I haven't had a problem..I didin't even think about it til I saw this thread.....
Just my .02.......(flame suit on and zipped.)
...JR
...JR
