Pic of the Shims installed?
Old Apr 25, 2002 | 01:21 PM
BOOST's Avatar
I am just about finished with this bastard of a mod. Before i tighten everything up i want to see a pic of the shims installed on someones bolt. Never dealt with these before so I feel uneasy. If anyone has one thanks. If not then I'll take it that my eye is seeing things correctly.
Old Apr 25, 2002 | 01:50 PM
ICULOKN's Avatar
I will look to see if I have any pics of mine installed...
The main thing is to make sure the thick part of the shim is towards the front of the rear and that you have enuff of the center pin showing to line up the rear...
Old Apr 25, 2002 | 03:27 PM
BOOST's Avatar
Thanks for the info. I am pretty certain everything is ok. I tighted everything up, and took it for a drive. No funny noises, nothing felt strange. SO i think I got it right. Woooo HOOOOOOO.
Old Apr 25, 2002 | 03:37 PM
ICULOKN's Avatar
Sounds good man, what degree shim did you install? are you lowered at all?
Old Apr 25, 2002 | 04:19 PM
BOOST's Avatar
3/4 drop 6 deg
