Please post where your idle is in drive
Old Apr 24, 2002 | 09:51 AM
415cid Goose's Avatar
Question Please post where your idle is in drive
Trying to compare with others where the idle is in drive. Mine seems a little low.
Old Apr 24, 2002 | 10:19 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Thumbs up
P = 850
N = 850
D = 700
and anyone here will vouch that I am absolutely normal.
Old Apr 24, 2002 | 10:54 AM
NeedFourSpeed's Avatar
Mines around 650-675. I think the spec calls for 675 in drive but I may be wrong.
Old Apr 24, 2002 | 11:01 AM
Chikenears's Avatar
Originally posted by Raoul
P = 850
N = 850
D = 700
Normal... hehehehehe!!
Old Apr 24, 2002 | 11:04 AM
Thanks guy's. Mine in D is 650.
Old Apr 27, 2002 | 02:01 PM
PFA's Avatar
PFA
I had to check mine after seeing this thread. Mine idles in Drive at around 560. It has a reman. engine in it with only 1300 miles on it, all stock. Seems to be pretty low???
Old Apr 27, 2002 | 04:13 PM
LightninSVT's Avatar
Mine is really low, i've posted many times about a rough idle, i think thats why it does it. Idles in drive around 550
Jon
Old Apr 27, 2002 | 08:58 PM
Chikenears's Avatar
Mine idles at right around 600 which I think is too low. It stalled on me making a quick turn at idle speed yesterday. The idle adjustment screw is on the side of the throttle body, right?
Old Apr 27, 2002 | 10:18 PM
svt360's Avatar
mines at 600,i think you have to play around with the throttle pos sensor to adjust it,i could be wrong!!
Old Apr 27, 2002 | 10:31 PM
Chikenears's Avatar
Somebody should know.. ttt
Old Apr 29, 2002 | 10:00 AM
There is a screw on the back side of the T/B behind the linkage. I recently learned there is a lock down nut that was never tightened after the bilet T/B was put on. Mine has a phillips head screw.
I may be wrong but I don't think you want to jack with the TPS because it will affect the voltage at the TPS. That voltage should read between .92 - .98.
Old Apr 29, 2002 | 10:54 AM
whip's Avatar
I'm by no means an expert, but I thought the idle had to be done on the chip (if you have one). If you adjust the throttle body, after a while the computer will "learn" that adjust meant and drop it down to where it was. Am I way off? Oh, and mines around 550, with the pulley, I get a little noise at idle, might have iot raised a little.
Old Apr 30, 2002 | 03:44 PM
ernie's Avatar
about 650 or so on the cabin tach in drive.
ernie
2002 F150 Lariat
ext cab/FX4
5.4L
etc., etc.
Edit:oops, sorry guys......this is the L board, and I found this post in a seach for idling problems.
Old Apr 30, 2002 | 05:20 PM
Raoul's Avatar
25 Year Member
Smile
That's ok ernie, we'll let it slide this time.
But this Forum is for those of us with hp...
Old Apr 30, 2002 | 06:23 PM
RTKILLA's Avatar
I've often wondered about that too, Mines around 600 at IDLE in drive and I would like for it to be around 700 to 750 in drive. and 800 in park. maybe I'll have sal reburn my chip again!
