Going back to the track friday with SLICKS!!!
Old Apr 22, 2002 | 10:39 PM
Bob Tompkins's Avatar
As my very good freind says "its time to dust the sand out of your ****"
I got my UTRA type 51's in today (16x10) and ordered some hoosier's 28x10x16 and I am gonna have a run at the local 1/8 mile friday night to see if i can dip into the 7's with it, I am pretty confident i can do it. The truck ran 8.40 @ 85.41 with a 2lb lower and a PSP street chip at the same track on f1's with 2.1 (im guessing the 60 ft clocks were broken) sixty foots. I was full weight with 3/4 tank of gas.
Current mods are as follows....
1. 4lb lower (psp)
2. 1lb upper (2.80 metco)
3. PSP filter kit
4. JDM flip chip - will run j69
5. factory tech valve body
6. JDM long tubes / cats / bassani cat back
The truck dyno's (407/515) I plan on dropping the hitch and spare tire tommorro night and install the drive shaft loop.
Anybody think I will make it to the 7's???
Any suggestion on getting the thing off the line (burnout and launch)???
What PSI should I run in the slicks??
Last but not least, any other suggestions you guys that have drag raced a bunch care to offer this novice.....
Bob
Old Apr 22, 2002 | 10:52 PM
SVT F15O's Avatar
Thumbs up Goodluck
Goodluck with your new tires. Let me know how they are I am looking to get a set my self maybe. I am running the Nitto D/R now and they are wearing fast. I do big burnouts on them and have netted a 1.82 best 60' I get consistent 1.85's all day long. I see no reason why you should not break deep into the 7's. Goodluck let us know how you do! -Mat-
Old Apr 22, 2002 | 10:53 PM
retics4me's Avatar
Make sure you CURE the slicks first before you go to the track .
Old Apr 22, 2002 | 10:57 PM
what does CURE mean????
Bob
Old Apr 22, 2002 | 11:56 PM
ICULOKN's Avatar
Bob
Take that advice. My new 28x10x16 Hoosiers gave me problems because I came the the track with them green(or New). Put them on go down the road, put some water under your tires and do a good burnout. Take the truck home and let them sit. You will be ready for the track the next day...
7's should be easy for you...
Old Apr 23, 2002 | 06:02 AM
Marc Carpenter's Avatar
Like ICULOKN said. First time at the track on green slicks sucks.
I was sideways, in and out of the throttle, and up in smoke as
soon as I hit the pedal.
As the day progressed, traction got better.
Marc
Old Apr 23, 2002 | 08:12 AM
beefcake's Avatar
bob, in georgia on my 12.49, before the lt's i ran a 7.941 1/8, i would think you should be right about there
Old Apr 25, 2002 | 12:11 AM
thx - boys
The drive shaft loop (metco) is on, it was a PITA because of the center console conversion but she is all back together now!!!!
I am gonna pull the hitch and spare tommorro, and pray my slicks show up as promised!!!!!!
Bob << getting antsy and wanting 7's real bad!!!
Old Apr 25, 2002 | 12:39 AM
hdmlnium's Avatar
Thumbs up
Bob,
Good luck on joining the 7 sec. 1/8 mile club, I think you will get it with out to much of a problem.
Bill
