Alignment are these numbers ok?
Old Apr 18, 2002 | 03:53 PM
QKSILVR's Avatar
I am alignment dumb. Are these numers ok
Old Apr 18, 2002 | 04:24 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
http://198.65.157.241/forums/showthr...ight=alignment
Lightning specs:
L.H. Caster: 6.9, +/- 1.0 Deg.
R.H. Caster: 7.4, +/- 1.0 Deg.
L.H. Camber: -0.5, +/- 0.7 Deg.
R.H. Camber: -0.5, +/- 0.7 Deg.
L.H. Toe: -0.05, +/- 0.15
R.H. Toe: -0.05, +/- 0.15
Lightning Owner preferred:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Base F150: (tolerances same as above)
L.H. Caster: 6.2
R.H. Caster: 6.7
L.H. Camber: -0.3
R.H. Camber: -0.3
L.H. Toe: 0.03
R.H. Toe: 0.03
Ford Alignment spec:
Lightning Owner autocross preferred specs:
LH Camber -0.7
RH Camber -0.7
LH Toe OUT 0.05
RH Toe OUT 0.05
Old Apr 18, 2002 | 05:05 PM
QKSILVR's Avatar
so they look ok then???
Old Apr 18, 2002 | 05:54 PM
if I'm reading the printout correctly (the AFTER row)
Left front camber is off (too little) as is the right camber (too much)
otherwise, good to go.
Was your gas take full when you took it in?
Old Apr 18, 2002 | 05:56 PM
J15BIG's Avatar
how much gas should you have when you go in for an alignment?
Old Apr 19, 2002 | 08:45 AM
QKSILVR's Avatar
yes matter of fact it was
Old Apr 19, 2002 | 09:07 AM
awhittle's Avatar
With what I see in the rear...I wonder if any of the front is correct. It looks like the machine is out of calibration.
