I just put ATF+3 in my tranny on accident! Help! [merged]
Old Apr 14, 2002 | 08:10 PM
dtdionne's Avatar
Well, i just finished the line valve mod, went to advanced auto, where they apparently cant stock shelves, to pick up some mercon/dextron III. Well I was stupid enough not to check to make sure that all the quarts were just that and ended up adding two quarts of ATF+3! What should i do?
Old Apr 14, 2002 | 08:19 PM
dtdionne's Avatar
Old Apr 14, 2002 | 08:27 PM
J15BIG's Avatar
drain the fluid and leve the pan and filter off for the night so the rest drips off. tomorrow mid afternoon put pan back on and fill with the right fluid. you may still have a little of the other stuff in their but i think you should be fine...thats what i would do at least.
Old Apr 14, 2002 | 08:32 PM
J15BIG's Avatar
just thought about something else....
maybe you can run a few quarts of the right stuff with the pan on to flush out the system then empty and refill again. might cost you a few bucks but it will be worth it IMO
Old Apr 14, 2002 | 08:34 PM
dtdionne's Avatar
I dont have another car, would i be ok to run to walmart to get somemore fluid?
That sounds good J15.
Old Apr 14, 2002 | 08:35 PM
L iminator's Avatar
Factory Tech
I would go to NLOC and find Factory Techs site and ask him. He knows what to do, no bout adout it.
Old Apr 14, 2002 | 08:42 PM
J15BIG's Avatar
if you have to...i would try to borrow a friends car or have someone go get it for you. but if you have no other choice you should be ok, i think
Odin's Wrath's Avatar
I'm pretty sure you're going to need a tranny flush to get all the unwanted fluid out. Someone will let me know if I' wrong. I'm 99.999999999% sure though. I don't think it will hurt to drive it to get the service done.
Old Apr 14, 2002 | 08:50 PM
J15BIG's Avatar
what exaclty is a tranny flush? do they use the right fluid and just run it through? is it pressurized or something?
Old Apr 14, 2002 | 08:59 PM
It's a pressure purge. All the tranny fluid will not just drain out. It must be forced out because there are areas in the transmission where the fluid pools. That's my general read on it anyway.
Old Apr 14, 2002 | 09:04 PM
Edward's Avatar
Lightbulb
See this extremely informative "How-to."
http://www.ford-diesel.com/faq/1999f...ance-AutoT.htm
Old Apr 14, 2002 | 09:11 PM
dtdionne's Avatar
dang, i cant find Factory Tech! Anyone know him?
Old Apr 14, 2002 | 09:12 PM
Great post! Thanks! That'll be good for future reference.
Roger
StruckBy99's Avatar
I dont know if ATF+3 will harm your tranny , but as soon as you start your truck the pump will mix all the fluid together (converter too). If that fluid is bad, drain it now.
Oh FactoryTech.........where are you?...........
J
Old Apr 14, 2002 | 09:16 PM
Spike Engineering's Avatar
I'd have it pumped out (flushed).
Spike
