One more time on Boost Bypass
Old Apr 9, 2002 | 11:29 AM
cabraco's Avatar
Is the boost bypass valve that bronze colored valve with the blue and yellow paint marks on it?
Old Apr 9, 2002 | 12:53 PM
Chikenears's Avatar
No it is not. These are the best I can do. Hope this helps.
Old Apr 9, 2002 | 01:38 PM
cabraco's Avatar
Ok, if I am seeing this right, the pink vacuum line that plugs into the top of the small black cannister with the yellow paint dot on it, is the line to disconnect and plug up. then run a vac line from the spot on top the cannister(where I disconnected the pink vac line) over to the installed T at the boost gauge line. Thans..........Buk,Buk,Buk
Old Apr 9, 2002 | 03:03 PM
cabraco's Avatar
TTT
