superchip and boost bypass
Old Apr 8, 2002 | 10:36 PM
Botter's Avatar
Question superchip and boost bypass
hello everyone. i just recently purchased a 2000 with 4000 miles. i first want to say how much i enjoy this forum, all the shared ideas and tips are great. it is obvious there is no end to all the mods i can do. to start out with i am going to install a superchip, new airforce one intake, and a boost bypass. my question is about the boost bypass. is it worth my while to get the bypass kit, what should i notice in improvements, and is there anything i need to be careful about by using it. thanks for any input, Greg
Old Apr 8, 2002 | 10:40 PM
ICULOKN's Avatar
Just unplug the boost bypass... NO need to by the $25 kit for a free mod...
Old Apr 8, 2002 | 10:43 PM
spanky777will's Avatar
Banned for Violation of Vendor Rules
air force one makes an intake for the lightnings? If you unplug it, it leaves a soft code in the computer.
ICULOKN's Avatar
The plug that has the label SC3 on it in the picture is what needs to be unplugged....
Old Apr 8, 2002 | 10:45 PM
ICULOKN's Avatar
You will never know it is there, if the SES light ever came on a simple removal of the negative side of the battery will clear it...
Save $25 for a sticker on something....
Old Apr 8, 2002 | 10:57 PM
E3LilE8Harv29's Avatar
I bought a plastic tee,2 short lenths of vaccum hose,plastic reducer coupling & a rubber stopper for about $5 from Home Depot. It takes all of 5 min. to install. You can even wrap a piece of loom around it to be fancy.
Old Apr 8, 2002 | 11:07 PM
ICULOKN's Avatar
Originally posted by Nitro Lightning
Taking into consideration that you post a reply on mostly everything here on F150, I thought it was time you learned something new.
When your computer wants to dump boost, and the solenoid is disconnected, it will not only set a soft code in the computer, but it will also put in a default value for the timing and fuel curve above 3 thousand RPM's, no matter who's chip you run, because the computer thinks its command was not followed.
That is why most all Lightnings equipped with the proper boost bypass kit not only run faster, but are more consistant than higher boosted, unplugged solenoid equipped Lightnings.
The kit fools the computer into thinking it did its job of dumping the boost and it will not change the timing/fuel curve to compensate.
Now do you think it is 25 wasted bucks???
I just thought you might want to learn something new.
Nitro
LOL this is worth a laugh....
I ran a 12.345,12.337,12.342, and a 12.339 over the weekend. That isnt consistent? How many other trucks running my mods are running that consistent? I even have removed a few parts and still ran some good numbers...
Faster?? http://www.nloc.net/forum/showthread...&threadid=9927
Check the list again.. True they have me in the wrong place but look where I stand based on my mods... I only have a few and have outrun some HIGHLY modded trucks....
Faster??
Old Apr 8, 2002 | 11:20 PM
ICULOKN's Avatar
I dont like messing with things that work man... Its been that way for over 13K miles and I have had zero problems...
BOOST DUMP happens when there is a problem. Tranny to hot, or Tires spinning, I think a few other things can make it happen as well. I try to avoid doing things that cause KNOWN problems.. Maybe one day I will make my own bypass kit, but I wont pay for one... Until then, mine will be unplugged.....
Old Apr 8, 2002 | 11:29 PM
ICULOKN's Avatar
So a soft code in the computer isnt a problem??
My soft code was reset almost 8 months ago and has not come back....
My truck has been on a Ford Scanner many times checking things...
Old Apr 8, 2002 | 11:36 PM
ASVTFordBoy's Avatar
Good idea. Save $20.
Just for the he11 of it, I may do this and see if I gain anything. I can't see gaining a tenth or two though. I have had mine unplugged for a while to with so problems.
The only thing that has caused mine to dump boost is overrevving the engine, which is usually only possible with a chip.
Old Apr 9, 2002 | 12:02 AM
ASVTFordBoy- Did you play hooky and go to the race today? Kennseth is HOT with 2 wins. Those Roush cars are dialed in!(I noticed the caption under your name)
Old Apr 9, 2002 | 12:11 AM
I wish I could have been there. A few guys I know go to the Texas race every year, and I keep saying that I'm going to go one year but never have. It's more like about 3 hours from where I live. Still close enough.
Maybe I should clarify and make it "5 minutes from the fastest drag strip in Texas", which would be Houston Raceway Park. Where records are broken almost every year at the NHRA Nationals, and it is very easy to run some kick a$$ times.
Old Apr 9, 2002 | 12:50 AM
Botter's Avatar
Thumbs up thanks for response
thanks for all the replies. hey nitro and iculokn, i didn't mean to stir-up such a debate!! lol i am new to doing mods on performance engines, so i dont want to hurt the motor doing a mod that might cause damage. i might try unplugging first, then see how it runs when i use the kit. i'll let you know if i notice any differences. thanks again
Old Apr 9, 2002 | 12:55 AM
ICULOKN's Avatar
Re: thanks for response
Its no biggy man, Many people have tried it both ways. I bet in reality there are about the same amount of unplugged to bypassed trucks out there. Like I said 13k with it unplugged and no issues...
