DL !!!!
Old Apr 8, 2002 | 02:05 PM
SVTRobG's Avatar
Question DL !!!!
Mr. DL,
What pressure do you run in your Nitto's at the track ???
Thanks bro
Old Apr 8, 2002 | 03:23 PM
HIGH ROLLER's Avatar
Nitto Tire Pressure
Hey Rob,
I believe David was running his Nittos at 22#psi
Matt
Old Apr 8, 2002 | 03:28 PM
SVTRobG's Avatar
Matt,
I forgot that you had them also. Any track time with those tires ???
Old Apr 8, 2002 | 03:48 PM
Cool
Rob,
I went yesterday on a opening day test&tune fighting the sleet and snow flurries at times and there was no rubber laid down at all on cold pavement but still managed a 1.90 which is not bad considering the conditions.I will try them again next weekend with the warmer air headed are way!David has had great results getting several 1.71-1.73 60ft.times on stock converter with 22psi in his tires.
Are you going to St.Louis in May again? Terry,Janis,myself and Jeri are going down on saturday!Hope to see you there!
Matt
Old Apr 8, 2002 | 03:56 PM
SVTRobG's Avatar
Matt,
It was opening weekend at Byron also. Traction was very poor for Byron so the modified trucks were getting killed by the stock trucks I should have the Nitto's by the end of the week so I'd like to try them out this weekend if I could. Dave seemed very happy with them.
P.S. I'll be in your hood either Thursday or Friday. Stop by Terry's if you can
