What degree shims after 3/4 drop?
Old Apr 7, 2002 | 10:20 PM
The Orphaner's Avatar
Registered User
Just wondering what shims everyone is using after 3/4 drop. I installed a 4 degree shim under the rear spring on the axle perch but it needs more of downward rotation...its near straight with the drive shaft now! Any suggestions?
Old Apr 8, 2002 | 12:27 AM
SpoonDog_SVT's Avatar
I have a 4-degree installed. No problems here (that I know of).
Old Apr 8, 2002 | 12:30 AM
Incon306's Avatar
My kit came with 6 degree shims.
Old Apr 8, 2002 | 12:54 AM
ICULOKN's Avatar
Mark,
I have a 3 deg and a 2deg to give me 5 deg total. I like the way the rear looks with that...
Old Apr 8, 2002 | 01:15 AM
JeffsLightning's Avatar
Originally posted by ICULOKN
Mark,
How does the rear look? Is the driveshaft straight with the pinion with the L sitting normally? Or is the pinion pointing down slightly? Also where could I get some shims? Thanks
Old Apr 8, 2002 | 01:18 AM
ICULOKN's Avatar
Pointing down just a tad, the traction bars keep it right inline under load. Most and spring or aligment shop will have them. Summit has them as well I think....
Old Apr 8, 2002 | 01:21 AM
Did you check your DS angle? I want to make sure mine is set just right before I bolt on the traction/lift bars. Thanks
Old Apr 8, 2002 | 01:22 AM
ICULOKN's Avatar
My dad did a EYE check.. He has setup many race cars over the years and I trust his EYE. It was good enuff for me....
Old Apr 8, 2002 | 01:26 AM
OK that sounds good. I will most likely do the same. Here is a picture of some shims. They are from Summit. Thanks for your help. http://store.summitracing.com/global...e/BEL-4975.jpg
Old Apr 8, 2002 | 01:29 AM
ICULOKN's Avatar
Those are it...
Here is some info from my experiances...
Stock 3deg shims work well
2in shackels 2deg shims
3/4 kit- Use 5deg shims
These are how I got my best results or pinion angle setup....
Old Apr 8, 2002 | 01:32 AM
I found these at Jegs. Maybe they will work better since I don't need that bolt right? http://www.jegs.com/photos/62020510.jpg
Old Apr 8, 2002 | 01:55 AM
Spike Engineering's Avatar
It would be best to measure the angles.
Spike
Old Apr 8, 2002 | 08:17 AM
cabraco's Avatar
Hey Spike, I am showing my ignorance here, but how do you measure the "angle" , and what "angle" are we talkin' about here? Is this where the drive shaft goes into the pumpkin??
Old Apr 8, 2002 | 09:37 AM
Here's a link with pix.
Spike
Old Apr 8, 2002 | 09:13 PM
outnumbered's Avatar
Did any of you have to install the Belltech Camber kit to have the front end aligned after the 3" drop up front?
