Calculating MPG??
Old Apr 5, 2002 | 03:05 PM
BLackBoLT99's Avatar
Suspended For Rules Violations
Question Calculating MPG??
How do I do this? Do I need to a full tank of gas? I need to test the MPG for a few of my chips. Thanks in advance.
Old Apr 5, 2002 | 03:11 PM
kidtriton's Avatar
Fill it up, remember how full you forced it (how many times you make it click off) You dont need to keep up with how much filled it up this time.
Reset your trip odo. Drive a while, over 100 miles for a good average.
Fill it up again, trying to get it the same fullness as the first time. This time, record exactly how many gallons and tenths it took to fill it back up.
Divide the miles you drove from your trip odo. by the gallons and tenths it took to top it back off.
Old Apr 5, 2002 | 03:14 PM
awhittle's Avatar
1) fill tank
2) reset odometer
3) drive truck
4) fill up the truck
5) type into calculator (miles on the odometer) divided by (gallons of gas used to fill up the tank) that’s why they call it Miles/Gallon
Andy
Old Apr 5, 2002 | 03:18 PM
PhillipSVT's Avatar
I think Jeffs on the ball. I alway's try to fill mine all the way up, till no more goes in. That way they are constant. Wind and speed also make a difference, so driving styles should remain constant. Just my thoughts
Old Apr 5, 2002 | 03:20 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Follow the directions above also,
Go to the same station, use the same pump.
For the same 'fullness' use the autolock on the pump handle, when it clicks off do not 'top it off'. (You may top it off at different amounts unless you just make sure your shoes get wet everytime) At the same time don't let the truck get jostled around by you or someone inside the truck.
Oh yeah, and pay for the gas before you leave.
Old Apr 5, 2002 | 03:23 PM
PhillipSVT's Avatar
What raol said, Would temperature effect the expanding of the gas, thus causing the auto click to click at a defferent level than before?
Old Apr 5, 2002 | 03:27 PM
kidtriton's Avatar
I think the differece in getting an extra few tenths of a gallon in there or not aren't significant. If you were doing it for a full tank (about 300 miles) it wouldnt mess up your calculations. Just dont pump it all the way up the filler neck one time, and stop on the first click the next time.
Old Apr 5, 2002 | 03:28 PM
Raoul's Avatar
25 Year Member
Originally posted by PhillipSVT
... Would temperature effect the expanding of the gas...
That's true Phillip, I know it does with me.
I just lift my leg and let it fly.
Old Apr 5, 2002 | 03:31 PM
thepawn's Avatar
In my current driving style *grin* I average 12mpg on my stock truck. (only have open air filter)
Daniel
Old Apr 5, 2002 | 03:46 PM
captainoblivious's Avatar
LOL
Old Apr 5, 2002 | 04:00 PM
webmaster's Avatar
F150online
Founder
...and don't forget to maintain this information using Ownersite.com
You can view my current MPG, maintenance history and estimated Cost Per Mile at http://www.ownersite.com/WindowSticker.cfm?veh_id=3323
Old Apr 5, 2002 | 04:35 PM
cteselle's Avatar
ditto... use OwnerSite! It rocks!
Old Apr 5, 2002 | 06:06 PM
FastAsL's Avatar
do exactlt what awhittle said. he is 100% correct!! you dont need to go to the same pump or remember how many times it "clicked" off. it is the easiest and the truest!!
