Annoying Lag in 2nd gear...
Old Apr 5, 2002 | 12:14 PM
TheSilverBullet's Avatar
What is that annoying lag that these trucks have when cruising in 2nd gear at around 2000-3000 rpm. I know of another L that has this problem...is it just us? Or is it everybody?
-Dan
Old Apr 5, 2002 | 12:55 PM
soap's Avatar
Disconnect the boost dump located on the drivers side of the blower that may help a tad
Notice the plug that is disconnected......it has 2 wires going into it.
--Joe
Old Apr 5, 2002 | 01:16 PM
Weedo's Avatar
I get a bad lag, chip or no chip, at about 3,800 to 4,000 rpm when i'm getting on it. Not sure if this is the same thing? I don't have a consensus on what it is yet, but i KNOW it's costing me a couple tenths in the quarter mile!
Old Apr 5, 2002 | 01:22 PM
LIGHTNINROD's Avatar
Soap:
I'm usually with ya, but on this one--I don't think it has anything to do with 'boost dump'. Yes, he should disconnect his if he hasn't already, but I don't think that that is his L's problem.
Having said this, I d/k what the problem is .....unless the PCM is backing out some timing???
Dan
Old Apr 5, 2002 | 01:23 PM
kidtriton's Avatar
it's the point at which the torque convertor is reaching 100% duty cycle (lockup).
Old Apr 5, 2002 | 01:35 PM
MiamiWhiteSVT-L's Avatar
Yup guys.........it's not the boost dump switch.........that has nothing to do with it...........I think the first post described it perfectly.............It's around that 2500 - 3000 rpm range that it does it ALL THE TIME...............WOT, half-throttle, 3/4 throttle, easy driving..........wHATEVER.........it always does it.....I thought the chip gets rid of it, but nope.....
Do the higher modded guys see the same thing????
JC
Old Apr 5, 2002 | 01:38 PM
Weedo's Avatar
Struck in AZ had mentioned the Torque Converter as well. How can this be fixed, it's annoying!!
Mine is ONLY at WOT, sorry if i'm confusing the issue but i wonder what mine is...
Old Apr 5, 2002 | 01:45 PM
kidtriton's Avatar
ok, one more time.... It's the torque convertor hitting 100% lockup. A chip can tune it out, although most programs don't get rid of it, but if you asked, it can be removed.
Old Apr 5, 2002 | 02:07 PM
Weedo's Avatar
Any reason NOT to get rid of the torque convertor issue with the chip? I would assume ALL Tuners would get rid of this as it lags the power.?.?
Old Apr 5, 2002 | 02:12 PM
kidtriton's Avatar
It keeps tranny temps down and the point at which it locks is near maximum power, so it makes it more efficient. I think it may help ET instead of hurt it. My 01L had only a JDM chip (which kept the lockup) and MT ET streets and had no problem running 12.80's in 90deg. July weather.
Old Apr 5, 2002 | 02:43 PM
xjmd44's Avatar
At least a tenth of a second!
Ya, the '00 Lightning I owned had this problem, until I installed Sals Flip Chip. I've not chipped my '01 Lightning to date, due to warrantee issues. However, I really believe a PSP chip installed in a '01 or '02 would eliminate this lull
Old Apr 5, 2002 | 04:07 PM
Weedo's Avatar
As far as helping the ET, there's not a chance! It is a noticeable lag, maybe 30hp for what feels like a half a second. This could only hurt the times, which, as stated, is why some tuners have been taking this issue out when they program a chip. I just wish mine was taken out. I wonder if everyone has this problem? I'm assuming yes.
Old Apr 5, 2002 | 04:27 PM
Weedo's Avatar
Old Apr 5, 2002 | 04:30 PM
kidtriton's Avatar
what you dont realize is that while you hear the engine bog down, it's like letting a slipping clutch the rest of the way out. It has nothing to do with the engine, so therefore its not a 30 or so reduction in HP. For that matter, what does it feel like when the truck goes into 3rd gear? Do you think that that's a reduction in power?
Old Apr 5, 2002 | 05:08 PM
xjmd44's Avatar
All moving parts ( Stand Still )
(A little Ozzy song)
Now jefflaws....Calm down bud. It's a fact that this lull Watching the tach stop for a moment in time! Does not hurt the qtr mile ET/Mph all that much (Oh Yeah) , but this bull S#!t anomolous shift pattern does chap the hide of most GEN2 Lightning owners. And by the way some chips do send this SLIP UP a steppin
