Alignment specs for a 2" drop?
Roger, Roger.
Lightning specs:
L.H. Caster: 6.9, +/- 1.0 Deg.
R.H. Caster: 7.4, +/- 1.0 Deg.
L.H. Camber: -0.5, +/- 0.7 Deg.
R.H. Camber: -0.5, +/- 0.7 Deg.
L.H. Toe: -0.05, +/- 0.15
R.H. Toe: -0.05, +/- 0.15
Base F150: (tolerances same as above)
L.H. Caster: 6.2
R.H. Caster: 6.7
L.H. Camber: -0.3
R.H. Camber: -0.3
L.H. Toe: 0.03
R.H. Toe: 0.03
Lightning Owner preferred:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Lightning Owner autocross preferred specs:
LH Camber -0.7
RH Camber -0.7
LH Toe OUT 0.05
RH Toe OUT 0.05
Lightning specs:
L.H. Caster: 6.2
R.H. Caster: 6.7
L.H. Camber: -0.3
R.H. Camber: -0.3
L.H. Toe: 0.03
R.H. Toe: 0.03
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
RH Toe -0.05 (same)
LH Camber -0.7
RH Camber -0.7
LH Toe OUT 0.05
RH Toe OUT 0.05
Who wrote up these specs, and who uses them? Is it a good idea to blindly follow something like this without asking?
I need an alignment soon so if anybody uses these specs, and they work good, please let me know.
Thanks,
Tim
Thanks,
Tim
I agree with chickenears, i've been looking to get a drop soon as well and although i have a shop to do it, i know its a shop that would be more familiar with regular trucks then L's. Where were these specs found??
~Toast
~Toast
