1st Tune Up
Old Mar 30, 2002 | 08:02 AM
Wantmorespeed's Avatar
Question 1st Tune Up
I am about to give my truck (1997 4x4 4.6) it's first tune up. I run her pretty hard and am considering the MSD ignition install at the same time as the tune up. What are the best plugs,wires, and all other tune up parts? I have read how difficult it is to replace the plugs and want to replace them with the best so they will last. Thanks.
Old Mar 30, 2002 | 08:07 AM
Don's Bolt's Avatar
I would just replace with stock parts. The spark plug change on your truck should be a lot easier than ours since you do not have any coil pacs to deal with.
I would ask your question in the engine forum, since our engines are quite a bit different than yours, they will be able to help you better over there.
Old Mar 30, 2002 | 08:08 AM
easterisland's Avatar
you may want to ask this question in a different forum. Such as the engine forum or regular f150 forum. Those guys may know more about it. You probably only need to start one thread instead of several.
Old Mar 30, 2002 | 08:09 AM
Will do it.
