Half a Lightning
Old Mar 27, 2002 | 03:08 AM
BABolt's Avatar
Cool Half a Lightning
Just wanted to post some photos of my little project. No it is not an item that is for sale. It is destined for my Ranger, which will run half a Lightning motor in displacement. This is half of my induction system and the other half will be a 90 cubic inch Eaton to help out the pumping choirs. Both will be intercooled.
Old Mar 27, 2002 | 03:11 AM
J15BIG's Avatar
you so crazy! LOL....looks great, good job. intrested in what kind of numbers that little sucker is going to make.
Old Mar 27, 2002 | 03:23 AM
BABolt's Avatar
Believe it or not the target is somewhere between 600 and 750 HP with at least 600HP at the rear wheels. The block in the photo is a 1979 turbo motor and it is brand new (23 years in the crate) and it's sole purpose is to be a test fixture. The real motor is damn near bullet proof as some of the ARCA guys may know.
Old Mar 27, 2002 | 03:48 AM
J15BIG's Avatar
holy *****. 600rw from a 4 banger. damn!!!!! thats truly crazy!! your a genius man!!
Old Mar 27, 2002 | 03:57 AM
Boostin01L's Avatar
Are you going to put that 600-700hp motor in a little tiny no weight ranger.Dear God that thing will haul @$$.
Old Mar 27, 2002 | 04:48 AM
BABolt's Avatar
Cool
That's the plan and this is the Ranger.
Old Mar 27, 2002 | 07:32 AM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
Hey, I think I've seen that garage before.
Bob
Old Mar 27, 2002 | 07:42 AM
LIGHTNINROD's Avatar
Dammitboy!
Mike: That's not '1/2 a Lightning'--that's a Lightning and 1/2!
Dan
Old Mar 27, 2002 | 09:33 AM
BadBolt's Avatar
With that much expected hp, will you have to use any kind of turnbuckle to hold the motor. And, what are your plans for the trannie and differential. Is this a Ford 9 inch type of setup.
Old Mar 27, 2002 | 10:24 AM
captainoblivious's Avatar
that is the sweetest exhaust manifold leading to a turbo that I have ever seen.
Old Mar 27, 2002 | 01:57 PM
BABolt's Avatar
Smile
Thank you Captain "O"
I must say that the header was designed not only for fit and finish but high performance too. It is a true 4/2/1 design of equal length ( maybe a little cheating )with a merge collector. I hope that we did our homework well as the diameter and length of straight pipe leading to the turbo were based on a theoretical perfect model. It is made from high heat stainless steel (321) and all tubes were polished before and after assembly. It is a one off and I intend to keep it that way by destroy the fixture it was built on. Thanks again.
Old Mar 27, 2002 | 02:20 PM
thepawn's Avatar
Talking
BABolt,
Please adopt me.
Pretty please.
Daniel
Old Mar 27, 2002 | 02:55 PM
Actaully I shouldn't have said manifold, thats a header leading to a turbo. Are they equal lenght? Also how many Esslinger Racing parts are on that engine?
Do you post over on the fordranger boards? If you do I would suggest not show those pictures cause they will probably hunt you down to do that work for them When I had my ranger I so wanted to drop in a 2.3L turbo with the t-5 transmission. Maybe one day.
Old Mar 27, 2002 | 02:58 PM
ICULOKN's Avatar
Babolt,
Everything you touch is like gold. You do some of the nicest work I have seen. I cant wait to see some #'s from that thing....
Way to go!!
Old Mar 27, 2002 | 06:42 PM
BDAZSVT's Avatar
Did you build the merge collector? I worked for a header company awhile back. We had our merge collector work farmed out because none of the guys in the shop could get them right. We copied Burns design and had Tim Engler do the hard work. Tim was one of the guys that built the multi engine pulling tractors and now builds sprint car motors. He is a very bright and talented guy
