PLEASE EDUCATE ME?/ Boost By-pass?
Old Mar 26, 2002 | 06:04 PM
E3LilE8Harv29's Avatar
As you can probably tell by all these posts, I seek knowledge! I hear alot about the Boost by-pass valve mods. What is it? Where is it? What does it do? As always guys, I appreciate all your input! THANKS!
Old Mar 26, 2002 | 06:10 PM
soap's Avatar
Just unplug the boost by pass on the driver side of the upper intake. It look slike this here.........
--Joe
Old Mar 26, 2002 | 06:13 PM
What will this do for my performance? Are there any negative effects? I have read posts on guys LOWERING the boost by-pass? Thanks!
Old Mar 26, 2002 | 06:23 PM
Don's Bolt's Avatar
Here is a pic of the JDM Boost BiPass kit. What this does is keep the boost dump valve from opening like in the picture above. This mod will never give you a service engine soon light.
You disconect a vacuum line install a T between two ther ines, and plug the hole where the vacuum line came from, and you will never loose boost again
Old Mar 26, 2002 | 06:49 PM
I'm still not clear on what is meant by "I will never loose boost" I can't say I have.
Old Mar 26, 2002 | 06:56 PM
J15BIG's Avatar
there is something called a boost dump. when the computer detects too much boost it will open the the boost bypass valve. you will still me making boost, it just will not be going into your engine. this doesnt mean that if you buy a 6lb pulley you will never have boost unless you get the bypass or unplug it, the bypass only activates when its "dangerous" or something, im sure someone that knows for sure will chime in and correct me if im wrong.
Old Mar 26, 2002 | 07:09 PM
clonetek's Avatar
if you hit your rev limiter during a burnout, the computer will activate the boost dump. this sux when trying to get a sub 13 second pass..
Old Mar 26, 2002 | 07:28 PM
Sorry I'm so thick guys! Now i'm diggin' what you are sayin! What vaccum line do you cut to insert the T?
Old Mar 26, 2002 | 07:39 PM
soap's Avatar
DO NOT CUT ANY VACCUM LINE!!!!!!!!!
Just pull apart the 2 that have a union holding them together.
--Joe
Old Mar 26, 2002 | 07:52 PM
KOOL! Thanks for all the help guys! Another project now!
Old Mar 26, 2002 | 09:15 PM
Rusty's Avatar
NO NEED TO BUY THIS BYPASS
its free just unplug the bypass exactly as the picture is and u will never lose boost again and it will never set off a check engine light. that is for free. some say if u do that u will get service engine lights this is not true. at least on my truck and several others i have talked to. simply unplug it for free and dont worry bout it. i used to lose boost at the track occasionally so i unplugged it. it has not been plugged in now for about 15000 miles now and never has set a code or set the light off! but if u feel like u need to spend a few bucks get the kit. just trying to save a fellow lightning owner a few bucks no pun intended.
Old Mar 26, 2002 | 09:40 PM
NOSTROMO
Guest
Posts: n/a
I thought the ECU would monitor the resistance of the dump solenoid coil windings? The plugging of the cauum line is the "proper" way to do it though. The ECU can still activate the soenoid but does nothing as it is plugged.
Old Mar 26, 2002 | 11:09 PM
awhittle's Avatar
see https://www.f150online.com/forums/sh...&threadid=65879
Andy
