Canton stuff- part #'s gains?
Old Mar 25, 2002 | 05:47 PM
easterisland's Avatar
Question Canton stuff- part #'s gains?
I'm thinking about getting some Canton stuff and wanted opinions. I also need to find out if the part #'s I have are correct and if anyone has tried this stuff and gotten any gains.
Canton products
oil pan #15784 (multi-baffled)
windage tray #20-939C
oil adapter plate(so I can use the accusump w/o rerouting the oil filter) #22549
accusump #24-004 (normal 3 quart) #24-014 (high pressure 3 quart)
CM filter #25-290(4 1/4 inch) #25-490 (6 1/4 inch)
Which accusump to get the high pressure one? Will some custom work need to be done to get the oil pan/or windage tray to fit?
Old Mar 25, 2002 | 05:58 PM
thulsadoom's Avatar
Talking
Good questions, I have been wondering about canton stuff as well. I will be watching for any replies!!
Old Mar 25, 2002 | 07:23 PM
Silver-Bolt's Avatar
You might see some gains with the windage tray. The rest is just very good insurance to a long motor life. Very import if you plan to use the accusump on the street. You have to remember to open the valve. Not sure the accusump is worth the trouble on a daily driver.
Old Mar 25, 2002 | 07:43 PM
LIGHTNINROD's Avatar
Don't
get their fuel filter. I did because their site listed it for F150s. It has line connectors that are too short--you can get the fuel lines hooked up but you will never be able to get the tool in to remove the lines.
Dan
Old Mar 26, 2002 | 10:13 AM
I think any time you can get oil circulating before starting would be good. I also plan on some auto cross for fun. You can get the electric valve and wire it to a switch or ignition for easy access.
Old Mar 26, 2002 | 10:14 AM
Will the pan fit?? adapter plate for accusump? Anyone?
Old Mar 26, 2002 | 10:39 AM
TimBurntire's Avatar
I inquired about a windage tray a while back and was told that since our engines rarely see the 6000 rpm mark that it would basically give no positive return at all.
Just what I was told for what it's worth.
Old Mar 26, 2002 | 10:41 AM
The windage tray is very inexpensive and I figured I might as well do it since the engine is apart.
Old Mar 26, 2002 | 12:06 PM
Ruslow's Avatar
If possible get a remote oil filter and run lines up to it.The reason being that when you open the valve for the accusump it sees no oil psi on EITHER side of the filter and unless it has an antidrain back valve in the filter[I don't know]the oil will take the path of LEAST resistance[which is back thru the filter and to the pan]In mine I put a ck valve that allows oil to flow to the filter but not back from it.That way I KNOW the oil is going to the engine on first start.stan
Old Mar 26, 2002 | 12:52 PM
Okay, thanks Stan.
Old Mar 27, 2002 | 01:02 PM
Stan, where did you mount the accusump and which line did you tie into, from the engine or return to the engine?
Also did you get the high pressure 3qt or the regular one? The High pressure one is 22 inches long while the regular is only 16.
Old Mar 28, 2002 | 11:23 AM
ttt
