Nitrous Question
Old Mar 25, 2002 | 05:01 PM
blown318's Avatar
Question Nitrous Question
What type of kit do all the nitrous users recommend?? Wet or dry?? I can pick up a brand new Dry NOS kit from a friend. I wanted to know the pros and cons of using both. thanx chris
Old Mar 25, 2002 | 06:38 PM
J15BIG's Avatar
most of the lighning guys that run nitrous use a wet kit. the only advantage i know of using a dry kit over a wet kit is fuel puddling up in the intake. but i have been told that with our engines we dont have to worry about that. i think if you asked all the tuners they would say go wet. its just safer. i also think that you get more power with a wet kit. i.e. when your setup for a 50 shot, you may get 45hp with a dry and 60 with a wet, i think.
Old Mar 25, 2002 | 07:31 PM
blown318's Avatar
NO nitrous users?? I know u guys are out there....
Old Mar 25, 2002 | 08:56 PM
lightning Jeff's Avatar
Go with a wet kit. Call sal at PSP. He seems to be the king at NOS tuning.
Old Mar 25, 2002 | 09:25 PM
rooster3038's Avatar
I have heard the wet route is better also. That way you don't have the worry of the computer not sending the extra gas since it's sprayed too. Also, if you add mods that get to a certasin HP range the stock injectors can not provide the needed amount of gas.
Old Mar 26, 2002 | 12:50 AM
HANKFAN's Avatar
NX is the way to go!
Old Mar 26, 2002 | 02:05 PM
HD Odom's Avatar
Cool
I too perfer the wet kit from NX. Just because I have never used the dry type I guess. However, if you can get a good deal on the dry go for it. Wet or Dry, be sure to invest the extra $35 and wire in a fuel pressure safety swich, which will insure that you get the needed fuel along with the N2O and your motor don't BLOW! $35 vs $3700 for a replacement long block plus labor, cheap insurance.
