Will this get me into the 12's????
Old Mar 24, 2002 | 09:05 PM
Lightning#838's Avatar
1999 L:
JL Air Filter
JL 4# pulley
JL Diablo sport chip
90 mm mass air
Borla Cat-back
Denso IT-22s
I'm thinkin low 13's high 12's. What do you think?
Old Mar 24, 2002 | 09:16 PM
TheHylandr's Avatar
I ran a 12.79 @ 108 this weekend with a JDM Flip Chip, JDM 2LB Lower Pulley, JL Stage 2 Ram / Cold Air, Line Mod Valve and Boost ByPass I ran full weight, nothing removed and 3/4 tank of gas.
I also lowered the pressure in the rear F1s to 25 PSI
Old Mar 24, 2002 | 09:17 PM
Lightning Boy's Avatar
Im thinking a mid to high 12 if you can get some traction.
Do you have a 99-00 or 01-02??? Big Difference
Old Mar 24, 2002 | 09:28 PM
With a C/F/P(2#) and slicks, we were able to pull off several 8.0x's in the 1/8 with our 99. That will convert into a 12.6 - 12.7 in the 1/4.
You have enough to make 12's, if you can launch it.
Old Mar 24, 2002 | 09:54 PM
01whiteLight's Avatar
Registered User
theoretically it should, but traction is a very big factor.
Old Mar 24, 2002 | 10:24 PM
HyE_BoLt's Avatar
That truck better be well in the 12z, if not, send all the stuff back. I wen 13.32 @ 101 with just intake and exhaust and ET streets. So figure half f that stuff is gonna give u 3 tenths. i think its a go. Good luck
Old Mar 24, 2002 | 10:28 PM
You guys are giving me good news.
Old Mar 24, 2002 | 10:50 PM
MiamiWhiteSVT-L's Avatar
Hey, I'm going to Moroso Wednesday..................If you wanna run your truck as is, without whatever you got on the way, let me know.............maybe we can meet up there or something.....I'm running bone stock, cause I wanna get a baseline run for comparison before I start modding next week............doing chip and throttle body, maybe the PSP/Factory Tech valve body also, depending how much I make on ebay this week.....I know it's gonna take a while to get it shipped since they're running behind on those orders, but at least I'll put the order in.
Anyways, email me................jguerr23@aol.com..........i get home 10-ish.........I can reply to you then..
lates,
JC
Old Mar 24, 2002 | 11:00 PM
poweredbySVT's Avatar
Unhappy
For all the rest of you good ole USA. WE are talking SOUTH FLORIDA. BIG Heat, BIGGER Humidity. We run consistently 3-4 tenths slower and at LEAST 2-3 mph slower than MOST of the rest of the country. For goodness sakes.....our COLDEST day this year at our track on a Test n Tune night was LOW 60's.
But I did squeek a 12.8@105 in that weather.
Don't forget Moroso WPB...the "REAL" slickest track of the south!!
Good Luck
Old Mar 24, 2002 | 11:11 PM
Pantera's Avatar
My'01 went 12.57 @109 with just a JL Diablo chip and a #3 JL pulley.
Old Mar 25, 2002 | 01:33 AM
JBLsilver01's Avatar
13.0 here w/the only hp adders being chip, intake and throttle body. Other factors are the ET STreets and a home-made air tube thing, but with your mods I would say mid to high 12's easy. The only way youd get a 13 would be if you gunned it hard off the line and spun bad............
Old Mar 25, 2002 | 01:35 AM
ICULOKN's Avatar
I went 12.50 with a 3lb lower, JL chip & filter, on ET's with the same setup I could do 12.60's with 1.8x's on the F1's....
