Observations during and after plug swap
Old Mar 18, 2002 | 12:06 PM
SVT-Snake's Avatar
I swapped out my stock plugs with NGK TR6's and I was wanting to post somethings I noticed and asked if anyone else did the same.
During: First off, I only changed 7 out of 8 since we could not get to the dirver's side rearmost plug. My stock plugs looked good except for it looked like the truck was running pretty rich which I sort of expected.
After: First thing I noticed was a more responsive throttle. Second I noticed their seemed to be alot more power, I knew their was a very slight bit of power to be had when replacing plugs but this was really noticeable. Thirdly, I got much worse gas mileage on my return trip home than the way their (No I wasn't getting on it, just set the cruise and went). Could this be due to the computer needing to relearn everything since we disconnected the power during the process? I thought it could also be a misfire but their is no way considering it is running like a champ.
Any one else notice any of these things? My mods are as listed if anyone was wondering. Thanks, Later.
Old Mar 18, 2002 | 12:56 PM
LIGHTNINROD's Avatar
Snake:
What were the gaps on your stock plugs vs. the new plugs? I believe a wider gap will enhance your mpg, so if the new ones have a smaller gap...............
Plugs don't(by themselves) add or give more HP unless there was something wrong with the old plugs. Yes, many have noticed a better throttle responce. The battery disconnect shouldn't have affected the mpg--IMHO.
It took me 1 hour each on #4 and #8(the one you didn't change).
Dan
Old Mar 18, 2002 | 02:09 PM
SVT-Snake's Avatar
I am pretty sure the old (stock) plugs had a gap of .044 just like the NGK's I put in. Their may have been something wrong with the old one's but I couldn't tell, maybe I will post some pics and you guys can tell me what you think. I will keep a close eye on my MPG. The power increase may be a mental thing who knows.
On another similar note, how snug is "snug enough" for the plugs, I mean how tight is 20ft/lbs? I didn't have a torque wrench, and even if I dd I doubt I could have manuvered it in their. I am just worried about the thought of a plug blowing out. Thanks for all the help.
Old Mar 18, 2002 | 02:33 PM
Frank S's Avatar
20 ft/pds isnt very much. Don't worry, if you have one backing out you will hear what sounds like an exhaust leak for a while before it blows out. I heard that sound for about a month before tightening the stock plugs.
Old Mar 18, 2002 | 07:26 PM
Snake:
According to Sal(and others, I'm sure), run them down snug/finger-tight and then 1/16th of a turn more . Remember, there are only 4-5 threads holding the plugs in an aluminum head--don't get them too tight.
Dan
