Lowering 1"?????
Old Mar 17, 2002 | 12:15 PM
Black2000L's Avatar
Lowering 1"?????
My questions is what should i do to lower my truck 1" all the way around. I have the 2" lowering shackles on there am thinking if i do springs only it will lower the front 1" and the truck will not sit even??? What are your suggestions????
Old Mar 17, 2002 | 01:23 PM
JBLsilver01's Avatar
If you do the front springs, the front will sit 1.5 inches lower than the back (mine does at least), so if you wanted to lower the front and have it even w/ the rear, you could do a shackle/hanger kit (in your case, you could just get hangers) in the back to give you about a 3 inch drop in the rear, which would be almost even with the front. I personally like the sport rake look with the rear 1.5 inches higher.
Old Mar 17, 2002 | 04:04 PM
Spike Engineering's Avatar
See suspension drop information at the NLOC.net road racing forum. It'll give you a good idea of the different drop heights associated with each manufacture.
Spike
Old Mar 17, 2002 | 09:09 PM
Black2000L's Avatar
Thanks to both of you for respoding. Definately some valuable information on that link.
TTT
Old Mar 18, 2002 | 10:14 AM
captainoblivious's Avatar
Yeah you may get more then a 1" drop from front springs once they settle.
Definately check out Spike's thread so you can see the difference between the different ones out there.
