Question for 3/4 dropers
Old Mar 16, 2002 | 11:08 AM
Boone52's Avatar
I was just wondering if you do the 3/4 drop on stock rims if you have to c-notch the rear? If you don't will the ride bottom out all over the place? I live in an Apt. complex and there are speed bumps all over the place, I don't want to ruin the truck or drag it all over the place.
Thanks,
Dan
Old Mar 16, 2002 | 12:12 PM
DJY1's Avatar
Boone52,
Yes with stock rims you will still bottom out. It is best to c-section the rear with a 3/4 drop or do the 3/3 where you just go up a notch in the rear with the shackles to avoid bottoming out.
djy
Old Mar 16, 2002 | 04:18 PM
ICULOKN's Avatar
2/3 here no C-notch!! Any lower and I would do it!
Old Mar 18, 2002 | 11:43 AM
WrongdayJ's Avatar
Here's mine with a 2/3 drop, stock wheels & tires.
No C-notch, no problems at all with rubbing or bottoming out.
Hell, the other day I put a 460 and a C6 in the back and still didn't rub or bottom out.
Hope this helps,
