2 ?'s on guages
Old Mar 15, 2002 | 12:01 PM
L in Detroit's Avatar
2 ?'s on guages
one: got in a tranny temp guage, what is the normal operating temp for the tranny and what temp should it be critical to cool things down..
two: on the passengers side fuel rail there is a bleed off valve, can i use this for a guages sending unit...
jim
Old Mar 15, 2002 | 12:03 PM
soap's Avatar
I am not sure about the tranny temp gauge, ask Lightning Jeff he installed one. And yes the schrader valve on the passenger side is the one you tap into for the fuel pressure sender. Make sure you use the adaptor or the sender will NOT fit into the valve.
The adaptor you need is the Autometer #3280 (it is the one on the right)
--Joe
Old Mar 15, 2002 | 12:06 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
one answer
Two: Yes, you can remove the bleed off valve and attach the fuel pressure sending unit in its place.
there is a special fitting though... lemme see if i can dig it up.
nevermind.... Sir Soap is da man
