Is alignment req'd. w/ a 1 / 2 drop?
Is an alignment required with a 1/2 drop? Are stock settings best, and what if autocrossed occationally? Finally, is any hardware needed? I thought I saw a thread re bolt kits.
Thanks much.
Thanks much.
These specs are for the '99's, I don't know about the other years.
Camber - LH -0.5°, RH -0.5°, Total/split 0°±0.7°
Caster- LH 6.7°, RH 7.2°, Total/split -0.5°±0.7°
Toe (- is toe out) LH -0.05°±0.15° RH -0.05°±0.15° Total/split -0.10° ± 0.25°
This is the information exactly as I got it from Matt at SVT.
Hope this helps,
Hope this helps,
