air fuel gauge Q
drivers side o2 sensor
I believe you tap into the BLACK wire on the drivers side oxygen sensor for your signal wire to the A/F gauge the other wires are for your power supply that is your own choice how you want the back light to work
Slick
Slick
I think that you can tap #87 on the harness. Just to make sure, I can find that harness on the pass side of the engine bay(where it goes into the cab) kinda behind the battery. Is that the easiest place to tap the wire?
THANK YOU!
Qball
THANK YOU!
Qball
