dash question
Old Mar 13, 2002 | 05:06 PM
Spade$'s Avatar
dash question
How do you pop out the cover over the light switch. Im trying to get back there to shave that **** so that i can turn on my fogs solo
Old Mar 13, 2002 | 05:11 PM
BMWBig6's Avatar
Carefully put a flathead screwdriver in the recess on the light control panel (at the bottom part line). Leverage the screwdriver gently so that the tip is pushing the piece forward, and the 3 clips inside will release after stubborn resistance. I got mine to come out after 2 clips released, and then I put down the screwdriver and gradually pulled the 3rd clip loose (no sense risking damage to the lip of the plastic part.
Old Mar 13, 2002 | 05:13 PM
Spade$'s Avatar
thanks wish me luck
Old Mar 13, 2002 | 05:25 PM
Spade$'s Avatar
k i got it out but.... ok how do i get this assembly open?
Old Mar 13, 2002 | 05:28 PM
Struck in AZ's Avatar
Dude...check you friggin' e-mail!
Old Mar 13, 2002 | 05:37 PM
BMWBig6's Avatar
Dude.... or go here!
http://www.svtlightnings.com/svt/foglamps/foglamps.htm
Old Mar 13, 2002 | 06:31 PM
superfords's Avatar
nevermind
sorry, I had listed a procedure that applies to 99 model trucks only, my fault.
you don't just pry the assembly out on 99 models, they work quite differently, if you pry a 99 out, you will most likely break it and it'll just hang there loosely until you buy a new one.
Old Mar 13, 2002 | 06:36 PM
My01Bolt's Avatar
Thumbs down
STOP!!! Don't try that on your 01 or you will have to replace the whole switch!!!!! I did that when installing my carbon fiber and broke the switch!!! Just do it as stated in the first response and you will be fine.
Old Mar 13, 2002 | 06:38 PM
My01Bolt's Avatar
Superfords edited his response .....oh well
