Want To Drop The Front 1"
Old Mar 13, 2002 | 12:37 PM
KGM's Avatar
KGM
Going to put in Herb's washers that I've had laying around for about a year and thought I'd lower it while I'm at it. Ideas and #'s please.
Old Mar 13, 2002 | 12:38 PM
ICULOKN's Avatar
2in springs for a F150 will give you 1 in on a L...
Old Mar 13, 2002 | 12:55 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Arrow
KGM,
Planning on doing the spring,washer, cam bolt install in addition to installing a set of Hawk brake pads.
I picked up a set of Eibach progressive rate springs from Mark @ Lightningforce for $150.
Bob
Old Mar 13, 2002 | 01:15 PM
KGM's Avatar
KGM
Bob is that going to give you 1"? Also can you put up a link to Mark. Thanks
Old Mar 13, 2002 | 02:56 PM
JBLsilver01's Avatar
I just put in Belltech 2" springs. Gave me a perfect 1" drop. Ive heard from a member here and a write up on Titus's L that the Eibachs lower it more than 1", more like 1.5 to even 1.75 - I dont konw for certain if that is true though.
The belltechs not only make the truck look better but make it handle better, not as much body roll, and they absorb bumps much better than stock.
Belltech part no. 4803
installation pics:
https://www.f150online.com/forums/sh...5&pagenumber=1
Old Mar 13, 2002 | 03:17 PM
Boostin01L's Avatar
JBLsilver01L
Could you post pics before and after?
Old Mar 13, 2002 | 04:20 PM
Boostin - i will have pics after my next wash/wax - i'll keep you posted.
Old Mar 13, 2002 | 04:31 PM
Boostin01L's Avatar
cool thanks
Old Mar 13, 2002 | 04:53 PM
Boostin01L's Avatar
What is the diffrence between belltech 4803 and 4804 I hear people with both is one a lower drop???
Old Mar 13, 2002 | 06:36 PM
Boostin01L's Avatar
ttt
Old Mar 13, 2002 | 07:08 PM
SVTRobG's Avatar
JBLsilver01,
The springs used on Titus' Lightning are from So-Cal Speed Shop. They are Eibach springs manufactured exclusively for So-Cal and they do lower a Lightning 1.75". That's the spring I installed on my truck, it's a progressive spring and the ride is fantastic. Here's a pic of the Eibach (gray) next to a 1" drop Hotchkis spring.
The Eibach springs were $ 120.00 for the pair.
I'm not sure what the difference is between the two - the F150 2" drop springs are 4803. And they drop a L 1".
Tip when installing :
Put a small hydraulic jack in between the upper and lower control arm to put upward pressure on the upper CA to break the ball joint loose easily when you hit it.
Old Mar 13, 2002 | 08:09 PM
Boostin01L's Avatar
So it seems like the eibach(grey) would not lower a Lightning more than 1 inch right?
Old Mar 13, 2002 | 08:36 PM
SVTRobG's Avatar
Wrong Boostin,
Remember, the Eibach springs are progressive so they compress a lot more that a specific rate spring ( like the Hotchkis ). That's the wierd, wild stuff with coil springs. The gray one lowered my truck exactly 1.75" and the black one only 1".
Old Mar 14, 2002 | 03:36 AM
Boostin01L's Avatar
