Best Fuel Filter?
Old Mar 12, 2002 | 03:51 PM
ICULOKN's Avatar
Best Fuel Filter?
Anyone have thoughts on a Better Fuel Filter for our trucks??
Old Mar 12, 2002 | 05:35 PM
DaveRed99's Avatar
i just did mine
i just did mine .. i used a stock one tho i think it would be oh k to use a stock one.....
dave
P.S I WANT ONE OF THOSE SHIRTS!!!! LOL
Old Mar 12, 2002 | 06:04 PM
Don's Bolt's Avatar
I have been using a wix fuel filter on mine, so far it is working , and it is less expensive than the ford filter.
Old Mar 13, 2002 | 06:50 AM
nikslightning's Avatar
Where exactly is the fuel filter on our trucks? Hows the installation?
Old Mar 13, 2002 | 10:01 AM
LIGHTNINROD's Avatar
nik:
It's located inside the left frame rail--near the driver's door. It can be a PITA to disconnect the fuel line couplings. You must get a fuel-disconnect tool--Snapon makes the best--DUH, but you can get one that will work from Sears, Auto Zone, Pep Boys, etc. Press the fuel pump shut-off switch and try to start the eng. to relieve the fuel pressure. You will still need a container under the filter to catch the fuel. When you go to disconnect the coupling, push the coupling towards the filter before you place the tool in the coupling. Takes a little patience and 'wiggling' to get the fitting off, but you can.
Dan
Old Mar 13, 2002 | 11:07 AM
ICULOKN's Avatar
Do you have a part #?
Old Mar 13, 2002 | 11:50 AM
Tachophile's Avatar
I haven't looked at mine yet.
Are these the same type fittings used in AC lines?...The doughnut looking things?
-Kris
Old Mar 13, 2002 | 11:55 AM
Tachophile's Avatar
'nuther question....
I posted a question about this some time ago, but I don't know if it was answered.
Since the stock filter seems to need replacing often, why not put a bigger filter in there...one with more surface area, maybe?
It seems that we could replace with a fuel filter from the heavy duty trucks...or do we already have that?
-Kris
Old Mar 13, 2002 | 12:00 PM
Don's Bolt's Avatar
Wix 33595
Old Mar 13, 2002 | 12:06 PM
01Lightning's Avatar
How often should they be replaced? I assume every 15K miles.
Old Mar 13, 2002 | 12:41 PM
Taco: Canton/Mesa makes a fuel filter(replaceable element) that has a larger surface area but, don't try it. I did(they said it was for F150s) but if you get the line couplings on---you will never get them off. They made the ends too short--fits the Thunderbirds, I think.
Sammy: yea, every 15,000 or 10,000 if you're '****' like ol' CC .
Dan
Old Mar 13, 2002 | 01:05 PM
PWR_WHLS's Avatar
Question
Why replace the fuel filter so often ? - thought this was done more towards the 20,000 + mileage or so... maybe this is standard and I don't know it.
john
Old Mar 13, 2002 | 01:56 PM
WrongdayJ's Avatar
Cut open your old fuel filter and you'll see first hand why we change them every 10-15 thousand miles.
NAS-TY.
Old Mar 13, 2002 | 02:10 PM
RTKILLA's Avatar
NAS-TY.
especially with certain types of race gas! Every 10K.
