3/4 damage?
Old Mar 11, 2002 | 11:52 PM
blowntruck's Avatar
Question 3/4 damage?
Hello all,
I got the Belltech 3/4 drop done last friday and the truck is bottoming-out, which I knew it was gonna do already. My question is, will that do damage if I dont get a C-notch right away? I mean im going to, but just need to get more money and find a place to do it. Thanks
Old Mar 12, 2002 | 12:21 AM
DJY1's Avatar
I don't think you will damage anything you will just have a unbearable ride. You might want to change the rear shackle to the other notch then your rear won't bottom out so much.
Because the rear will be raised up a inch.
I did the C-section right after I did the 3/4 Bell Tech I could not take the bottoming out in the rear while going over speed bumps and pot holes in the roads.
djy
[img]//www.f150online.com/galleries/cover/gallery535.jpg[/img]
Old Mar 12, 2002 | 12:29 AM
jabtay's Avatar
I have a 2/4 and i have never had a problem of bottoming out. All i did was cut the bump stops down a little.
Old Mar 12, 2002 | 12:50 AM
DJY1's Avatar
jabtay, Lightning are already 1 inch lower than regular F-150's that is why your truck is not bottoming out.
djy
